Old 09-16-2008, 09:45 AM
brewcity1 brewcity1 is offline
Default Control 24 fader issue.
Hello,
I have checked through the entire forum for an answer (sorry if I missed it), and I am sure it's just a button that is enabled or disabled, but when using the control 24 faders during mixing of a Pro Tools session, some faders will move when I touch them (this is what I want), and some are stuck in position. If I go into Pro Tools via the mouse, and move the fader in Pro Tools, the fader on the Control 24 does move to the position within Pro Tools. If I go back to the 24, the fader won't budge at all.
Is this a setting that I have enabled or disabled?
Any help would TRULY appreciated.
Thanks so much.
Old 09-16-2008, 10:34 AM
Scott Goldberg Scott Goldberg is offline
Default Re: Control 24 fader issue.
Originally Posted by brewcity1 View Post
Hello,
Thanks so much.
You might first go to peripherals and hunt for the control 24 via ethernet hunt and reestablish a sound connection with the board. If that doesn't work, try the old pref trash and database go way. Use the linke here :www.jcdeshaies.com and see if that helps. You'll have to hunt for the board again in peripherals but what the heck?
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 09-16-2008, 11:00 AM
Thanks so much for the reply Scott. I'll give that a try tonight.
I did forget to mention that I am using Pro Tools 7.4 LE on a pc, not a mac, and it's interfaced with a 002R.
Old 09-16-2008, 11:23 AM
Sorry to say that I don't know a lot about the rest of your setup but my gut feeling is that it has nothing to do with your problem. This is a communication problem or a corruption at some level. You should (I hope) be back in the black soon! Best of luck!!!
Scott Goldberg
Gold Recordings
Control 24 Fader Issue youngas75 ICON & C|24 19 06-25-2015 02:39 AM
Scribble strips issue D-Control Fader Pack kptkarl ICON & C|24 0 01-13-2014 10:31 AM
Fader Control issue Sonic Blue Meanie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-21-2012 09:33 PM
'Fader Pack' and ProControl Fader order issue Ciaran ProControl, Control|24, Command|8 2 03-22-2005 12:58 AM
Control Surface - Behringer B Control Fader BCF200 ironfin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-14-2005 11:19 PM
