Old 01-23-2003, 06:39 AM
Graeme Oxby Graeme Oxby is offline
Default recording levels
Hi folks
can you tell me if by inserting a plug in (software) compressor on a channel during recording actually records that audio compressed or is it just compressed on playback.
IE I want to max amount of signal to noise without peaking and without going through an external hardwrare device.
Thanks
Graeme [img]images/icons/confused.gif[/img]
There's no "I" in "Team". But there is a "me" if you look hard enough.
Old 01-23-2003, 06:54 AM
j old school j old school is offline
Default Re: recording levels
If you have a plugin on the actual audio track, than you are not recording the compression, you are compressing the output signal of that track. If you want to do that, route the input to an aux track, and add the plugin to the aux track. Then bus the aux track to an audio track. That way, the signal reaching the audio track's input will be compressed, and recorded that way.
Old 01-23-2003, 10:27 AM
Mark Staples Mark Staples is offline
I've actually done it that way, but I found that I gain no real benefit because it's still post-converter.
Your BEST solution is to add compression before the converter. That way you get the hotter signal and the fatness of the analog compressor.
Mark Staples
Hearts of Fire Productions
email: [email protected]
Old 01-23-2003, 10:33 AM
That does makes sense - I have an outboard compressor in between pre and 001, so I never had to try it all within protools. I don't think it can be done without outboard gear.
Old 01-23-2003, 03:02 PM
JMS40 JMS40 is offline
Hi Jonah-
You can choose how much Normalizing you'd like.
My advise is to make sure you leave room to peak well below zero for tracks that will have additional processing.
The only time I Norm to zero is on a final master ready to burn.
Old 01-23-2003, 04:06 PM
Jonah Jonah is offline
Hi JMS
I geuss that's what I meant but didn't make it too clear. To clarify, I record everything and when I'm in the final mix, I normalize before I compress. Thanks for pointing that out.
Old 01-23-2003, 05:14 PM
Hi again Jonah-
We're on the same page.
I just wanted to point out for Graeme that you can set Normal so it peaks at any point you'd like below zero.
Can come in handy tweaking levels for individual tracks.
Good luck-
Old 01-23-2003, 07:31 PM
msenger69 msenger69 is offline
Silly question here, but is there a little headroom between when the meters go red and the sound actually distorts? If so, how much? Thanks!
--Mark
Old 01-23-2003, 08:03 PM
Meters go red, you're in distortion. Actually, you should leave at least .3db of headroom and never go to zero.
Mark Staples
Old 01-23-2003, 09:21 PM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
<font size="2" face="Verdana, Arial">Actually, the red meter doesn't literally mean "distortion", nor does it mean "clipping". What the red indicates in PT is that a certain number of consecutive samples were full scale. If I remember correctly, it's 3 full scale samples in a row will cause the red indicator. That is most likely a clipped waveform, and most likely distorted since true flat-top signals are rare in nature (or the studio). But it is not absolutely, for sure, clipped or distorted just because 3 consecutive samples happen to be full scale.
But, even still, it's a bad thing to see the red ever in a digital audio recording system.
Mike
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Recording Levels in a DAW Kenny Gioia General Discussion 2 08-10-2013 09:40 AM
Best Recording Levels spaceman Tips & Tricks 102 11-26-2011 06:53 PM
Recording Levels ahanslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2010 12:36 AM
Recording levels MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 31 05-31-2004 07:48 PM
Recording levels nickair Pro Tools TDM Systems (Mac) 2 06-23-2000 10:11 AM
