Old 12-26-2016, 09:57 AM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
Default HD driver and question answered about compatibility with Blue interfaces.
[edited] I ran into some issues with the newest HD drivers because I had not installed the corresponding Pro Tools version. I'm going to leave the post though in case it helps someone else avoid the same issue.
I was considering going from 12.5.1 HDX, OS X 10.5.5 to 12.7 while I had projects finished up. I have an Avid i/o and an old blue 192. I decided to install the HD driver first to see if it caused issues. I've always been concerned about "breaking" the 192. I use 8 analog when I need more than 16 (which is rare) and I use 8 AES daily for routing to outboard.
I installed the new 12.7 HD driver and AES on the blue stopped working. I uninstalled it and instead did the 12.6.1 driver and it was still broken. Fortunately I still had the installer for 12.5.1 and installed the HD driver and it fixed the problem.
Honestly, I don't know if this it and I will not be upgrading beyond this point, or the issue was that I put in HD drivers that were beyond the 12.5.1 software. If anyone can confirm they are using AES with HDX and the blue interface, that would be great, but I wanted to let people know my experience and possibly save them some hassle. I know a lot of people are still using those interfaces.
Last edited by Neale Eckstein; 08-20-2017 at 07:49 AM. Reason: Not my question anymore. SOLVED
Old 12-26-2016, 11:33 AM
denka's Avatar
denka denka is offline
Default Re: Using a blue 192 i/o? Beware the HD 12.6.1 and on driver
You must have DigiLink I/O asset in your iLok account in order to use ANY Avid interface incl. the blue ones.
That's a new thing started with 12.6. AFAIR.
Check with support if you're eligible for free asset otherwise it's one time payment for all interfaces you have and costs $299 in Avid store
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8
Old 12-26-2016, 01:05 PM
Yes, I have it. And everything worked but the digital I/o on the blue.
Old 12-26-2016, 01:25 PM
denka's Avatar
Check your i/o setting. Mine was completely hosed when I first got in touch with new HD drivers. I had to reassigned everything from the scratch and then all was all right with my Blue interfaces including AES i/o on HD 192.
Old 12-26-2016, 01:32 PM
Well they were grayed out. I guess I'd love some confirmation that digital I/o still works on 12.7. I know they had to a complete rewrite and since the blues are no longer supported, it might have disabled them. Not intentionally, but at some point I assume they will stop working with the latest software, either Avid or Apple. If I were prudent I'd just freeze the system but I enjoy knowing how to use the latest features.
Old 12-26-2016, 03:14 PM
denka's Avatar
You'll get the same answer from Avid or other end users as I am that Blue interfaces are fully supported in 12.7. Of course, I'm fully aware that the day of complete EOL will come but nobody know when. When this happens, I'll just buy grey, green, yellow or whatever color it'd be.
Old 12-26-2016, 03:25 PM
Thanks. Possibly it didn't work because I hadn't actually done the 12.7 update.
Old 12-26-2016, 03:43 PM
denka's Avatar
I'd suggest you to rename the subject of your thread or to add "solved" as this could be misleading to DUCers.
New HD drivers work only with 12.6.1 and later.
Cheers! :)
Old 12-26-2016, 04:19 PM
I'm happy to delete the thread entirely if it causes problems, but for now I edited it so others don't make the same mistake I did.
Digi002 works on Mac, not on Windows. ANOTHER Digi002 works on both hammerfied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-20-2016 02:38 PM
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 04:13 PM
at last it works gibboau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-12-2008 02:31 PM
Nothing works Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-27-2003 03:10 PM
It Works! My Protools system works!!! Woooooo Hooooo!! Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-19-2003 08:48 AM
