Old 04-19-2010, 07:04 PM
rosk8s rosk8s is offline
Default DAE Error 1115 encountered
I am getting "DAE Error 1115 encountered" when trying to open pro-tools. I've looked though this forum a lot trying to find the solution to my problem. None of the solutions that others used worked for me.
I've been running Pro-Tools LE 7.1 with Win XP on my Dell Dimension 4500 for almost a year with no problems unitl now. About a week ago I cut the power to my house to do some electrical work. Unfortunatley, I had a session in Pro-tools open at the time. When I turned the power back on and tried to re open pro-tools I started getting this "DAE Error 1115 encountered" message while the program loads. It gets to "Creating DAE obects" and then freezes and the message pops up. I click OK and program closes.
I've also noticed that windows media player will not work. This problem started at the exact same time the PT problem started. I mention this incase helps to give an indication to the savy troubleshooters out there.
To solve my Pro-Tools problem I've tried the following.
uninstalling and re-installing Pro Tools (several times).
Un-installing and re-installing my sound card
Deleting Digi Design Databases from C and E drives and restarting.
- Deleting DAE and Pro Tools preference files
- Deleting the Digidesign Databases folders for all hard drives
Nothing seems to work. I'm not really sure what to do from here.
Here is my Sandra Report. If any more info is needed for anyone to help me, I surely supply it.
ThankYou in advance....
SiSoftware Sandra
Computer
Model : Dell Computer Corporation DIM4500
Workgroup : WORKGROUP
Host Name : skatemas-6db8da
User : COSTA
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.00GHz
Speed : 2GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 8kB, Synchronous, Write-Thru, 4-way, 64 byte line size, 2 lines per sector
L2 On-board Cache : 512kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector
Computer
Mainboard : Intel D845EPT2
BIOS : Intel Corp. A03 07/18/2002
Bus(es) : X-Bus AGP PCI IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 2GB DDR
Chipset
Model : Intel 82845E Brookdale Host-Hub Interface Bridge (E0-step)
Front Side Bus Speed : 4x 100MHz (400MHz)
Memory Bus Speed : 2x 100MHz (200MHz)
Memory Module(s)
Memory Module : Centon JIYG18TVB 1GB 1GB DDR PC3200U DDR-200 (3-3-3-8 2-11-0-0)
Video System
Video Adapter : RAGE 128 PRO Ultra GL AGP (Microsoft Corporation) (AGP 2.00)
Storage Devices
WDC WD800JB-00JJC0 80GB (ATA100, 8MB Cache) : 75GB (C:)
SAMSUNG SP1203N (120GB, ATA100, 3.5", 7200rpm, 2MB Cache) : 112GB (E:)
WDC WD10EAVS-00D7B1 (1TB, USB/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) : 932GB (F:)
HL-DT-ST GCE-8400B (ATA33, CD-RW, 8MB Cache) : 522MB (D:)
Logical Storage Devices
Hard Disk (C:) : 75GB (NTFS) @ WDC WD800JB-00JJC0 80GB (ATA100, 8MB Cache)
PROTOOLS (E:) : 112GB (NTFS) @ SAMSUNG SP1203N (120GB, ATA100, 3.5", 7200rpm, 2MB Cache)
Pro Tools LE 7.1 (D:) : 522MB (CDFS) @ HL-DT-ST GCE-8400B (ATA33, CD-RW, 8MB Cache)
3.5" 1.44MB (A:) : N/A
Hard Disk (F:) : 931GB (FAT32) @ WDC WD10EAVS-00D7B1 (1TB, USB/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache)
Peripherals
LPC Hub Controller 1 : Intel 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge
LPC Legacy Controller 1 : SMSC LPC47M10X/112/13X
Audio Device : Dell 82801DB/DBL AC'97 Audio Controller (ICH4/ICH4-L A1)
Audio Codec : Analog Devices 0072h
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : Dell 82801DB/DBL (ICH4/ICH4-L) UltraATA/100 EIDE Controller
USB Controller 1 : Dell 82801DB/DBL USB UHCI Controller #1 (ICH4/ICH4-L A1)
USB Controller 2 : Dell 82801DB/DBL USB UHCI Controller #2 (ICH4/ICH4-L A1)
USB Controller 3 : Dell 82801DB/DBL USB UHCI Controller #3 (ICH4/ICH4-L A1)
USB Controller 4 : Dell 82801DB/DBL USB 2.0 EHCI Controller (ICH4/ICH4-L A1)
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 04-19-2010, 07:06 PM
Default Re: DAE Error 1115 encountered
I'm using an M-Box audio interface
Old 04-19-2010, 08:53 PM
sunburst79 sunburst79 is offline
Given the fact that Media Player isnt working combined with the fact the power got cut with the computer on leads me to think it may be one of two things
A) The OS some how got corrupted because it wasn't shut down correctly and you will need to reinstall Windows.
B) Theres also a chance the voltage spike or drop out fried your sound card and or the Mbox. This is if you are using somwthing other than the MBOX2 as you sound card. If your using the MBox as your soundcard than its fairly likely that "electrical event" damaged it.
I would try to install the MBox on another computer and see what happens.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-20-2010, 04:55 AM
thanks for the input
Old 04-21-2010, 06:56 PM
ok. I installed Pro-tools on on different computer with my MBox hooked to it. Then I went to open it and then the same error message popped up.
Also, before doing this. I tried to see if I could play thru my digi box (hooked up to my original compter) and hear sound. I could here plenty of sound going throught the M Box. I spoke into my mic and it was plenty loud. Is it still possible that the box is toasted?
Old 04-22-2010, 01:46 PM
are there any other settings on my computer that I should check?
Old 04-22-2010, 07:46 PM
I'm assuming your monitoring it at the MBox? without using any software? Is the box lit up? Have you tried a different USB cable....
Scott
Core 2 Specs Page
Old 04-23-2010, 08:24 AM
petersrin's Avatar
petersrin petersrin is offline
Firmware issue? Reinstall the Mbox firmware perhaps?
Old 04-23-2010, 09:32 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Try jus unhooking the Mbox(safely remove), then delete the databases folder(on all the drives) trash them, restart, plug the Mbox back up, & see what happens...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-29-2010, 09:29 AM
I’ve had my computer re-formatted now and had windows XP re-installed. I will now re-install Pro Tools LE 7.1. If I get the same error then I am to assume that my MBox is fried. If that is the case than what will be the likelihood that my Lexicon Lambda Audio Box/Interface (that I sill have from my brief stint with CuBase) will work with Pro-Tools?
DAE error -1115 was encountered? Glasshousefields 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-21-2010 09:25 PM
DAE error -1115 was encountered Renan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-16-2009 12:58 AM
DAE ERROR-1115 was encountered debardalo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 10-07-2009 10:53 PM
DAE Error -1115 was encountered DJTMS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2007 08:35 PM
"DAE error - 1115 was encountered" in LE w/ 002 uberhuberman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-04-2007 10:06 AM
