Old 09-06-2018, 01:33 AM
PierrevC PierrevC is offline
Default Channelstrip automation bug
Hey Avid,
Got a little automation bug with channelstrip.
Group 2 tracks, enable all controls in the globals.
When you drag an EQ-Dot everything works fine except when you control-drag to change the Q of a band. The grouped EQ-Q does not follow.
Dragging the Q-button works as expected.
Don't know if this only applies to Channelstrip.
Anyone else seeing this?
I'm on ultimate 2018.7
Excellent work on the search and multi-select menu's!
Regards,
Pierre
iSeeSound.be | Audio Post Production
Old 09-06-2018, 09:51 AM
filmixer filmixer is offline
Default Re: Channelstrip automation bug
It's always done that. Don't know why they can't fix it. It works if you use the knob, but not with the CTL modifier. Same thing happens with EQIII BTW.
Mark Ettel C.A.S.
Old 09-09-2018, 02:24 AM
Ok, thx filmmixer.
So used to my d-cmd knobs this issue did not bother me until I had to do a quick job on S6 the other day...
While we're at it copy-pasting plugin settings should also follow groups imho.
EQ7 and Channelstrip Bug in PT 12.8.1? RedMonkey Pro Tools 12 11 09-15-2017 08:12 AM
If you could only have 1 TDM channelstrip... BasketCase Pro Tools TDM Systems (Mac) 6 10-19-2013 08:43 PM
MHL channelstrip digigirly Pro Tools TDM Systems (Mac) 19 01-24-2004 11:46 PM
why no channelstrip? beatheavy Digidesign Hardware & Software 1 11-29-2000 09:43 AM
Channelstrip to another PT set DannyVanSpreuwel Pro Tools TDM Systems (Mac) 1 11-10-2000 06:24 PM
