Old 08-31-2018, 03:54 PM
bigbuddy3 bigbuddy3 is offline
Default Re: Record Clips Starting at a take number other then 01?
No, Im not using plays list, This is about individual record files
see pict. One Track.. Going in and out of record
Bob_01, Bob_02, Bob_03.
What I want is Bob_200, Bob_201, Bob_202...etc
Thx
File Type: jpg Screen Shot 2018-08-31 at 3.50.19 PM.jpg (18.9 KB, 0 views)
Old 08-31-2018, 04:22 PM
BScout BScout is offline
Do it in playlists.
Comp the playlist.
You'll get the naming you want. Record in playlist view if not seeing all your takes at once seems foreign.
ADR has been done a long time in Pro Tools and the workflow works (and is fairly standard everywhere.)
The file name always takes the track name. The number after the name with (after the dash) changes all the time due to editing/clip separation. You can't count on the post dash numbering (go back and do one edit and your numbering will suddenly be off.)
Or if you go in order, batch clip rename and then commit the clip name to file name. The suffix numbering will accomplish what you want. (commit clip name to file name is just select all the clips -- as long as they are still full files -- and open to rename all files and just hit enter through which will transfer the clip name to the file name.)
Old 08-31-2018, 09:06 PM
its2loud its2loud is offline
There’s no way to start ProTools takes with a preset seed number. If youre recording linearly, best to just keep track of takes and batch renumber at the end of the record and export the renumbered clips.
Playlists work great for ADR but not for linear recording on the timline with fast start/stops. After 100 takes the playlists take up too much screen space. Especially if recording multiple people at the same time.
If I need to renumber the takes I make periodic markers of what the take is supposed to be so I can go back and spot check that my renumbering is correct.
Old 09-01-2018, 09:31 AM
Trying to control Pro Tools' automatic suffixes is almost impossible. Do what most of us do: Use playlists and increment the playlist to stamp take numbers in the file. If you find the "_xx" suffix that Pro Tools adds to that file (i.e. Bob.201_xx) objectionable then just batch rename the clips to strip off the last 3 characters of the region name.
There are some hoops you can jump through to get the auto suffix to start at _01 again; here's a post on how to do that: http://duc.avid.com/showpost.php?p=2434791 But there's no way to start at some arbitrary number.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-05-2018, 03:45 PM
Thx for all the input ) as stated can not use playlist method in workflow.
Best!
Does number of clips effect the speed of a session? ianbee Pro Tools 10 4 09-14-2013 05:51 PM
Naming of clips when audio file ends with a number John Link macOS 5 06-02-2013 04:36 PM
Help-delay when starting record Jeff ONeil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-14-2010 01:24 PM
Lag when starting record WeNdeL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-23-2006 09:45 AM
OT......Starting a Record Label Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-17-2003 06:06 AM
