Old 08-13-2018, 10:02 PM
bigbuddy3 bigbuddy3 is offline
Default Record Clips Starting at a take number other then 01?
H,
I know PT Names the record Files of what ever the Track is named and adds sequential numbers at the end 01, 02 , etc
What I want to do , is to be able to start the sequential numbering at another number, such as 200,201 . etc .
It doesn't seem to matter if you rename clips and or files on disk.
PT picks up counting from the last take...
Thoughts?
Thanks!
Old 08-14-2018, 08:42 AM
Default Re: Record Clips Starting at a take number other then 01?
Just name your first Playlist as "Audio.200" and let PT count up from there
Old 08-31-2018, 09:46 AM
Thats not what I need.
If you name Track XXXX_200 all following takes will be named . XXX_200_01, XXX_200_02.
What I need is XXX_200, XXX_201.etc
Thx
Old 08-31-2018, 10:01 AM
The Weed's Avatar
The Weed The Weed is online now
Why not just Batch Rename the Clips?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-31-2018, 12:22 PM
dwaynedelario dwaynedelario is offline
What Albee said is correct. Don't rename the track, but the playlist. i.e. name your track, create a new playlist first and change the number in the popup window to whatever you want the first take to be. If you already have playlists, create a new one and rename it and it will count up from there.
MacOS 12.4 / Pro Tools Ultimate 2022.4
Old 08-31-2018, 02:17 PM
The work flow does not/can't use playlists, this is for VO Dialog record work where a client wants to start from take ...ex xxx_200..xxx201..xxx202, Takes are recorded sequentially/linear on one track.
Renaming afterwards doesn't solve the the issue.
Thx!
Old 08-31-2018, 02:26 PM
HI,
Ah yes! Thx
I created a new track, then new playlist changed to 200.
This does what I was looking for!!!
Thx so much!!
Best!
Old 08-31-2018, 02:51 PM
Ugh, I jumped the gun... Clips still don't count they way Im looking for,
Play list only takes on new name, ex ...xxx.900, clips count xxx.900_01, xxx.900_02
as opposed xxx_901,xxx_902
Thx
Old 08-31-2018, 03:02 PM
Let's say you have a track called ADR1. If you create a new playlist, and change the name of that playlist in the pop-up window from "ADR1.01" to "ADR1.900," you should get your first clip named "ADR1.900_01" and when you create the next playlist for the next take, it will be named "ADR1.901_02."
You are creating a new playlist every time you record, correct?
Old 08-31-2018, 03:08 PM
Here is a screenshot of what it should look like following this procedure.
Does number of clips effect the speed of a session? ianbee Pro Tools 10 4 09-14-2013 05:51 PM
Naming of clips when audio file ends with a number John Link macOS 5 06-02-2013 04:36 PM
Help-delay when starting record Jeff ONeil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-14-2010 01:24 PM
Lag when starting record WeNdeL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-23-2006 09:45 AM
OT......Starting a Record Label Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-17-2003 06:06 AM
