Understanding AFL/PFL--
I just upgraded to HDX AAX and was setting my my I/O and wasn't entirely sure how to take advantage of the Afterfader and Prefader Level setup. Presently, AFL/PFL is set to none. I have a D Command and am able to Solo tracks without any problem. I have researched the Reference Manual and I am not sure if there is some "great" feature that I am missing out on. Please help me connect the dots!
Re: Understanding AFL/PFL--
So you're not missing anything per se, but there is some special functionality added when things are set up this way. For example, it annoys some people that you can't solo a submix in PT's Default Solo In Place because the members of the group are then cut. AFL allows you to do this. It also allows you to solo things without their effects which can be useful. |
ihatetyping |
Thanks Drew and Elicious.
Generally used for live and broadcast.
I do like haveing it set up in the studio for: A) when doing overdubs sending you mix to the artist, you can solo someyhing without interrupting the artist. B) when mixing through a bus you can use PFL for scrubbing.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I was aware of PFL/AFL in Pro Tools and on studio consoles, but I never made the connection with the broadcast consoles that I used for 11 years when I was in radio. On the old Gates consoles that were in use back in those days, the "audition" bus provided AFL, while the "cue" bus provided PFL. The audition bus was accessed via an "audition/off/program" switch on each channel, and the "program" VU meters and control room speakers could be switched to the audition bus. This allowed us to set the levels of the mics for a "live" show on the audition bus, then switch the inputs to the program bus when it was "showtime". The "cue" bus was accessed by turning the channel pot all of the way down until it "clicked", and the signal would then be routed to a small speaker on the "front" of the console. The cue bus could only be accessed by the line-level inputs (turntables, tape decks, network feeds, etc). Having the cue bus only accessible when the channel pot was turned completely down helped prevent us from accidentally sending the sounds of us manually spinning records back-and-forth to cue them out over the program bus (although it did happen from time to time). And I suppose there is a certain irony in guys getting paid millions to create the turntable "scratching" that we were paid just a hair above minimum wage to avoid...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
I use it regularly to "hear just the return." (as someone's already mentioned earlier in the thread).
It's brilliant for those times when you just need to hear the verb or delay without hearing the dry stuff feeding that verb or delay. It also gives you a different perspective on tracks in your mix when you're used to hearing them with all their sends (and returns) active. You can get to hear them totally dry with just one press on a solo button. This is cool for problem solving without having the mute all your FX or mess with complex routing.
Cool & Informative Video Tutorials from Groove3 |
Need Help Understanding 888 I/O | Jason Kardong | Pro Tools TDM Systems (Mac) | 9 | 07-16-2009 01:37 PM |
64 bit understanding | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-08-2009 03:34 AM |
Understanding TLSpace | p4tw | Pro Tools TDM Systems (Mac) | 1 | 01-27-2006 01:04 PM |
I need a little understanding | Young&Aspiring | General Discussion | 1 | 01-17-2006 05:58 AM |
Understanding EQ | HR123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-11-2003 12:53 PM |
