Old 02-15-2010, 04:20 PM
Digitopian Digitopian is offline
Default Is there a solution to the bouncing midi folder yet?
Sorry to ask, but although I found many threads regarding the problem, I couldn't find anything regarding a definitive solution. I didn't even notice that I had this issue until today as I keep my taskbar hidden.
So is there a fix that doesn't create other problems? In case it is not in my sig., I am running the dreaded 8.03cs1 on OSX 10.5.8.
Thanks in advance!
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive
Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet
Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc.
UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors
Old 02-16-2010, 10:45 AM
DigiTechSupt's Avatar
Default Re: Is there a solution to the bouncing midi folder yet?
No, there is no definitive solution IF you are on a 002/003 and want to use the MIDI ports on those units.
If you aren't using a 002/003 or have a different interface (Mbox 2, etc) you can remove the DigiDioMidiDriver.plugin from the MIDI Drivers folder at MacHD>Library>Audio.
Avid Audio Tech Support
Support FAQ
Old 02-16-2010, 01:09 PM
gthm's Avatar
gthm gthm is offline
Double checking: Is this driver for users of the DIGIDESIGN MIDI I/O interface?
Old 02-16-2010, 01:31 PM
As stated by Digdesign, it is a driver for the Digi002/003 family of Protools LE interfaces only. (Not the DIGIDESIGN MIDI I/O that is normally part of the Protools HD family of interfaces)
Obsidian Dragon
Mac Studio M1Max - 64GB
Firewire Midi Solution dopewerewolf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-05-2007 01:54 PM
Midi Solution... Jagg76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-09-2007 06:54 PM
Possible solution to not seeing 002R midi/wav glogulus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-20-2003 01:30 AM
MBox Bouncing mystery, a solution? Hskala 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-18-2003 09:20 AM
Finally a solution for bouncing midi to wav! theregressor Digidesign Hardware & Software 0 11-18-2002 08:16 PM
