Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-29-2007, 05:26 AM
mingustoo mingustoo is offline
Default \"fuzzy/hissy\" playback
When playing back a mix I sometimes get a 'fizzy' sound. It is more prevalent in full mixes with more plugins. Is this to do with ram or firewire perhaps. Im on a Macbook core 2 duo 2.33 with 2 gigs ram. Two hard drives (7200, and 10000 rpm) are daisy chained after a firewire 410 which is plugged into the macbook. I have both processors on and allowed up to 90% cpu. Additionally, hardware buffer is at 2048--what gives?
Old 09-30-2007, 10:01 AM
digidesigner digidesigner is offline
Default Re: \"fuzzy\" playback
I do not mix on my m-powered laptop, I just record mixdowns with it from my PT mix system if it has all tracks in use. But I always run my MIX system thru my m-powered and output all sounds to speakers thru my M-audio Lightbridge. So I sometimes have stereo tracks at my m-powered pro tools (different versions of a mixdown) and I have noticed, that when playing back the tracks my system makes weird noises time-to time. It makes some "ZAP" and "ZIP" kind of sounds in random places that are errors not in the waveform. I tried to locate the problem and changed the buffer size for that (I use 1024 usually) and after just changing the value to something different and then changing it back will make the error sound go away for a while. Maybe thats the same you are getting.
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
Fuzzy\distorted playback of recorded audio. Caatalyst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-04-2011 03:19 PM
Hissy Fades scottgreiner Pro Tools TDM Systems (Mac) 8 09-30-2006 08:06 AM
Hissy music....help. lightning ad Post - Surround - Video 5 02-05-2005 11:22 AM
Fuzzy distortion on my playback. Help! halley362 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-21-2004 04:26 AM
