Magic ID does not match ????
PT7 quits rignt after creating an aux track ... I can'y seem to re-open my session...is there a trick ? Best, A. |
Re: Magic ID does not match ????
Try using Import Session Data -- sounds like an incompatible plug-in or corrupt session --- Import 1 track at a time.
Rail
Hi Rail,
I've already tried that.... ??? I keep getting the same message !!!! How can I import only one at a time ? Best regards, A. |
In the Import Session Data dialog you get to select what to import -- select only the first track (to begin with).
Have you removed all 3rd party plug-ins? Try that as well. Rail
Hi Rail !
Thanks for supporting ! I can't get the Import Session Data dialog to open... It keeps giving me the same error (or I'm dumb) ! I've removed also 3rd party plugins. A. |
So you create a new session at the same sample rate and bit depth as the session you're trying to open. Once the session is open... in the File menu under Import -- select Session Data... (Shift+Option+I).
A dialog will open where you can select the session file you're having issues with. Do you get this far? Select the session file and hit OPEN. Do you get this far? Rail
Ok Ok Rail !!!
I was doing it the right way and i KEEP getiing the same error !!! Best, A. |
Where?
Tell us where it fails -- I asked in my last post about where it failed in 2 locations. Email me a session file. My email address is in my profile. Rail
Hello Rail,
It fails when I try to import the data in the first place ! I've emailed the file to you ... Hope you can help. Best regards, A. |
Hello Rail,
Magic ID does not match.... | ziggypop1111 | Pro Tools TDM Systems (Mac) | 28 | 06-05-2015 12:46 AM |
Magic ID does not match | shea | Pro Tools 10 | 6 | 10-10-2013 04:56 PM |
SOMEBODY HELP ME!!!! 'Magic id doesn't match' | DW7000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-17-2009 09:56 PM |
Magic ID does not match | oigresbg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2009 01:45 PM |
HELP: Magic ID does not match... | aziel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-29-2003 02:28 PM |
