Old 01-06-2010, 04:14 PM
Digitopian Digitopian is offline
Default Re: Advice needed:HDD Cloning strategy questions
I suppose in addition to my original questions regarding my strategy for upgrading to a larger drive without having to do a fresh install, I should add to the pile the question of when and How to make the smoothest transition into SL. Although I believe my current system drive is fairly untainted(stable and clean), I always like the idea of knowing that my current installs are clean.
Would a good approach be to set up SL on the freshly wiped original drive after I know i have a stable Clone drive of my current setup running, and slowly build things up from there?
Also is there anyway to simply transfer the plugins folder from the clone drive to a drive with a fresh install of Sl and PT thus eliminating the hassle of reinstalling a ton of plugins?
Once again, sorry for all the questions.... Drive cloning and manipulation is unfamiliar territory for me other than in theory.
Thanks,
Ethan
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive
Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet
Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc.
UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors
Old 01-06-2010, 09:28 PM
humpback humpback is offline
Can't comment on Super Duper, but we've used CCC at the school I work at (114 stations of PT and other apps of various flavors) extensively. Works a charm for cloning - and have had no probs with non-ilok based authos, when we use CCC.
YMMV.
Best
Nathan
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x Summit Audio 2BA-221>TLA 50>EQF-100
2 x dbx 165a
4
x Shadow Hills GAMA
http://humpbackmedia.net[/SIZE]
Old 01-06-2010, 09:42 PM
YMMV.
Best
Nathan
Nathan,
This is very encouraging! Could you give me an idea of which non I-lok based plugins are installed on the stations at the school.
Thanks in Advance,
Ethan
Seeking advice on timing / strategy for upgrade to HD innerbooty Tips & Tricks 3 04-16-2009 11:07 PM
Pro advice needed Everything Pro Tools TDM Systems (Mac) 2 05-23-2006 11:55 PM
Advice needed... piework 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-18-2005 01:33 PM
G5 or HD? Advice Needed mantisgroove Tips & Tricks 27 09-17-2004 01:45 AM
Advice Needed On LE bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-06-2003 09:20 PM
