Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-22-2007, 08:02 AM
capitala capitala is offline
Default \"Playback\" Button Delay Issue
Hello
Everytime I press the "play" button there's like a 1 second delay before the button lights up and actually play, besides that, everything is fine. It's just annoying and I don't know what to do. I get the same result when I use the ProjectMix Controller or keyboard. I have Protools 7.3.1 installed, Mac 10.4.6, and the lates version of M-Audio driver updates. Is this something I can configure within Protools Setups to correct the issue
Old 05-22-2007, 09:02 AM
spkguitar's Avatar
Default Re: \"Playback\" Button Delay Issue
Do you have a countoff enabled? Or a pre-roll?
Old 05-22-2007, 09:22 AM
I will check both, thanks
Old 05-22-2007, 09:49 AM
feinded feinded is offline
Also another setting to try is in "preferences" It is the setting right above your auto save. Dont remember exactly what its called. Anyways, limit that to the max amount record time. Default setting is unlimited i belive. The setting basically reserves HD space and somtimes that you will get a little delay before you playback. Hope that helps.
weird button issue stormmusic Post - Surround - Video 6 07-11-2012 02:22 PM
Recording with playback - Delay issue ddj1991 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2011 02:51 PM
Hitting Play or Record, blue stop button lights up... delay Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 11:33 AM
Delay When Record/Play Button Pressed kaoticjackal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-25-2009 01:42 PM
Anyone find the fix for the play button delay? Parisstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-04-2005 09:14 AM
