Old 11-01-2020, 11:18 PM
sonicdogg sonicdogg is offline
Default Need help configuring an Omni
Forgive my ignorance as I searched and didn't find what I needed.
I have an Omni that I want to use the spdif I/O to an outboard CD burner which also has a digital I/O in order to make safety copies outside of my computer storage as well as make cd copies for clients who use them in their car as do I.
I can't seem to make this work and the book mentions the spdif briefly and even shows it hooked up to a DAT.
The funny part is I had it working at one time exactly as I have it planned but in rearranging my console it got unhooked and scrambled and now I cant figure it. I think the hardware setup page is correct but maybe not.
Thanks. In advance. No shaming please. I have 32 channels of I/O with Ultimate running an Avid 16 analog and a AD-16x. The omni is basically the playback distribution and an extra couple of mic pres.
Old 11-03-2020, 07:04 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Need help configuring an Omni
Difference from before when working?
Sample Rate
Digital cable
Control panel in Omni
Old 11-03-2020, 07:24 AM
^^^ all needed info.
You mean an Avid HD IO 16x16 and a AD16X and an Omni?
How exactly are they connected? Did that DigiLink or sync/clock cabling/config change? How is the AD16X configured on DigiLink, did this change?
We cannot guess what you are doing or can see. What shows up? Do you see all the DigiLink interfaces in Pro Tools hardware setup?
Old 11-05-2020, 01:34 PM
nst7 nst7 is offline
In hardware setup, make sure the optical output is set to Spidf rather than Adat, if you haven't already done so.
Also, wouldn't it be faster and easier to just bounce down a file and use a disc burner, or are doing it this way so you can monitor in real time as it's recording?
Trouble Configuring Avid Omni For Surround jrs320 Pro Tools HDX & HD Native Systems (Mac) 11 04-09-2017 09:17 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
configuring AMS Dopamine MIDI 3 02-18-2006 02:21 PM
Set Up / Configuring help Kawi Tips & Tricks 3 06-23-2005 09:15 PM
