Old 01-17-2006, 02:04 PM
GlennR01 GlennR01 is offline
Default Odd Midi/Virtual Instrument Problems with PT7+
I sorted thru prior posts and have not seen an issue exactly like the one I am having. I have disabled the multi-processor function for RTAS plugs. When using an instrument track with midi and any virtual instrument, then overdubbing on a different instrument track with a different virtual instrument, the original track & vi will sound when the midi keyboard is played, even though the original track is not in record and on a different midi channel. I am now going back to using midi tracks with separate aux returns. Although this option works more reliably for this issue than using instrument tracks, until I actually engage record in the second midi track, the active keyboard will play midi into the first midi track and sound notes thru the first virtual instrument even though that midi track is not in record.
Yes, I have had inputs assigned to the instrument track (as per the workaround described by Digidesign in their Read Me).
This one has me baffled. Any thoughts would be greatly appreciated.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 01-17-2006, 02:24 PM
Ray Lyon Ray Lyon is offline
Default Re: Odd Midi/Virtual Instrument Problems with PT7+
You might have the MIDI pref checked that enables MIDI thru upon track selection... try changing that pref to when the channel is put into record... hope this helps...
Old 01-17-2006, 02:28 PM
jeremyroberts jeremyroberts is offline
Glenn,
From the "What's New in HD 7.0.pdf" - page 62
Also, Pro Tools Reference Guide - page 189
You have discovered a new (very much wanted) feature -- in that you can use the selected midi track as your midi thru - even if it's not record enabled. This is an OPTION that you can select (or change or disable if you hate it - I love it).
You really should read the "what's new in PT7" docs -- you'll discover a lot and this kind of stuff won't hang you up.
oops--- Ray got the answer out before I could finish typing. Good job!
--Jeremy
Old 01-17-2006, 06:43 PM
Gentlemen, much embarassment here - I'm usually the first to recommend the manual, but apparently the last to take my own advice. In skimming thru the "What's New" manual, I didn't grasp the major signal re-routing that the simple "midi thru" would make.
So, now Jeremy, what do you use it for and why do you love it so much? I guess I don't see the use for it, but it might be the way I use my rig. And thanks Ray.
Virtual Instrument Problems TheMusiKing93 Pro Tools 10 5 01-18-2012 04:17 PM
Pro Tools 8 virtual instrument problems kimballob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-02-2009 11:40 AM
A.I.R. Virtual Instrument Boxset Problems sinlum Virtual Instruments 4 12-18-2007 11:51 AM
Virtual instrument latency problems!!!!! ScottFB Virtual Instruments 6 07-23-2007 09:22 AM
Virtual Instrument Recording Problems AdrianLesher Virtual Instruments 0 11-18-2006 11:44 PM
