Old 02-05-2007, 12:54 AM
Wai Hang Wai Hang is offline
Default Digidesign M-Box 2 Pro Users:
I have a Digidesgin M-Box 2 Pro. Finally, I got it work.
I hooked up to my DJ mixer to the box and I was wondering if I use the Monitor Output
to hook it up to the amp and speakers. Does the sound quality become better through the M-box? Or it will be the same quality as the mixer to the amp?
I would like to learn more things about the M-Box 2 Pro. Does anyone know where I can get some lessons or info about the Pro Tools or M-Box 2 Pro. Please let me know. Thanks
Old 02-05-2007, 01:26 AM
Default Re: Digidesign M-Box 2 Pro Users:
For Analog Output you have two choices here my friend, either your Amp has Monitor Control and in which case you'd route out of the Line Out 1 & 2 or if your Amp doesn't have Monitor Control and/or you'd like to control the monitor levels with the Mbox 2 Pro, you'd route out of the Monitor Out 1 & 2.
For Pro Tools tutorial, you should watch your Method One DVD that came with your Mbox 2 Pro Pack.
filosofem
Aaron Mulqueen - 001 HD Native
Old 02-05-2007, 10:57 AM
Default M-Box 2 Pro Monitor Output
Using M-Box 2 Pro's Monitor Output to the Amp and speakers, Does it help to imporve the sound quality? Or Is it same as Mixer to Amp and speakers?
Method 1 :
DJ Mixer to M-Box 2 Pro then to Amp and Speakers.
Method 2:
DJ Mixer to Amp and Speakers.
My question is "by going through the M-Box 2 Pro does it help to make the sound become better quality?"
Old 02-05-2007, 11:21 AM
Default Re: M-Box 2 Pro Monitor Output
Yes, some Mixers can degrade the signal, so it depends on the quality of the Mixer. The easiest way would be to try both configurations, so then you can determine which configuration works best for you.
The cleanest path would be to have 'Active Monitors' routed straight out of the Monitor Outs 1 & 2 on the Mbox 2 Pro (generally, less connections/devices makes for a cleaner signal).
filosofem
Old 02-05-2007, 01:03 PM
cary chilton cary chilton is offline
I am an mbox2pro user as well.... Can anyone suggest some killer active moniters? I have been looking at the Adam 7a and the p11a, or the new jbl's, PCM's (forget the model right now) or dynaudio bm6's.... anyone ????
Old 02-05-2007, 01:24 PM
JBL ...but I'm biased.
Cary, personally, I'd try and have a listening session with them all, take along one of your well known CD's and just listen to the different response each Monitor displays. Generally, Monitor selection is very subjective and really only you can make that decision.
Good luck.
filosofem
Old 02-05-2007, 11:01 PM
So, the cleanest path is to go through the M-Box Pro 2 to Amp?
Old 02-05-2007, 11:14 PM
Is that what you found?
filosofem
Old 02-07-2007, 08:29 AM
rockwilder rockwilder is offline
also biased , I can recommend the adam P11's, had them for over three years still happy with it. clear and detailed, good stereo image ... if your going for subbass material you'd need a subwoofer.
Old 02-07-2007, 08:57 AM
what was the inital problem with your mbox2pro ?
Why had Digidesign Abandoned NI users wmmccoy Pro Tools M-Powered (Win) 0 12-20-2005 09:44 PM
digidesign please do us LE users the favour and... gregor rasek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-10-2003 07:25 AM
All Digidesign Users Chazperx Post - Surround - Video 0 08-01-1999 08:26 PM
All Digidesign Users Chazperx Pro Tools TDM Systems (Win) 0 08-01-1999 08:22 PM
All Digidesign Users Chazperx General Discussion 0 08-01-1999 08:19 PM
