Old 08-06-2019, 04:28 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default EdiCue v3 released
I'm proud to announce the release of EdiCue v3. Here is a list of what's included in this major update:
  • New 64bit app with updated user interface that is macOS dark mode and HiDPI compatible
  • PDF layouts that can be designed to customise every element including adding logos and selecting which fields to display
  • Controls to style the ADR cue 'Line' text to bold, italic, underline or set the color of the text
  • A 'Segment List' to allow cueing of multiple reels or episodes in a single session
  • The option to export PDFs with editable fields so that TBW PDFs can be edited
  • Detail rows in the ADR summary to breakdown each character by Priority, Cue Status, Reason or Reason Category
  • Additional fields in each cue including a new BVox (Breaths and Vocals) checkbox
  • New 'token' setting fields to customise the contents of the exported filenames and cue numbers
  • Updated Import ADR Data window that automatically aligns the destination fields
  • New PDF data import option to import data from edited fields in an EdiCue PDF. E.g. TBW PDF
  • Production settings file can now be stored in a custom location. E.g. external or network drive
Here's a video outlining the new features:
https://youtu.be/_R3T7DFGwN8
For a full list of features see this blog post. You can also download and install EdiCue v3, where it will provide the option to activate a three day trial license when first run. Running EdiCue v3 will not effect any EdiCue v2 files.
NOTE: EdiCue v3 requires either macOS 10.10+ or Windows 8+, while EdiCue v3 licenses require a 2nd or 3rd generation USB iLok or sharable iLok license.
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 08-08-2019, 04:20 PM
mfranken's Avatar
Sounds In Sync
Default Re: EdiCue v3 released
Just released #EdiCue v3.0.1 to fix 4x bugs:
  • Fix to allow styling of ADR cues with non-English text
  • Fix to set character ID correctly in cue numbers that are printed in time order PDFs when using the global cue count method
  • Fix to stop crash on startup when EdiCue is run on macOS10.10 or macOS10.11
  • Fix to calculate the total number of cues and BVox cues in the character list correctly when the production is setting the BVox state automatically
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Old 10-16-2019, 09:29 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.1.0. This version includes the following updates:
  • Changes for compatibility with macOS (10.15) Catalina
  • New buttons in the Manage Productions window to Import and Export project settings
  • New ADR cue counting method to reset the counter with each new segment
  • Fix to be able to load ADR cue data from EdiCue PDFs containing editable fields
  • Fix to load scene numbers correctly from PDF shooting script files that display the scene numbers in the left and right margins
  • Fix for "Okay" buttons sometimes not showing in macOS dark mode
  • Mod to allow scene bands to be exported in PDFs when the scene data doesn't contain scene descriptions
  • Minor updates when creating editable fields in EdiCue PDF files
  • Minor update to Get and Set Pro Tools clip code
  • Optimisations to the load and save project settings code
Mark Franken, MPSE
Old 10-24-2019, 10:28 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.1.1. This version includes the following updates:
  • Bug fix to allow import and export of Excel files (issue started in v3.1.0)
  • Minor UI changes
Mark Franken, MPSE
Old 12-05-2019, 04:21 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.1.2. This version includes the following updates:
  • New 'ADR Summary Type' option "Segment Detail". This lists the segments in the detail section of the summary PDF, text and Excel files
  • Character and Department IDs are now displayed with the length set in the production settings when set above 3 chars
  • Any space characters found in the cue numbers of imported data are now converted to underscore characters rather than removing them
  • Fixed crash bug that occurred while in dark mode during data load after session interface window had been open
Mark Franken, MPSE
Old 01-27-2020, 09:04 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.1.3. This version includes the following updates:
  • Fix to Session Interface window so that text is pasted into stylable fields with any styling removed
  • Session Interface window 'Auto Update Text during Paste' setting now works again
  • Minor updates to user guide
Mark Franken, MPSE
Old 03-30-2020, 09:54 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.1.4. This version includes the following updates:
  • Multiple fixes to handle cues that use footages so data is loaded, displayed and exported with the correct cue locations (hour start)
  • Fix to clear the styling in stylable session interface window fields when all text is deleted
  • A check to see if any MIDI commands will be created before 00:00:00:00 while exporting MIDI files
  • Minor fix to make sure default extensions are shown while setting the name of exported files on macOS
Mark Franken, MPSE
Old 06-06-2020, 04:40 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.2.0. This version includes the following updates:
  • New Export Movies and Export WAV Files windows with integration with Todd-AO's Actors Mobile ADR. For more information see this blog post.
  • Fix so that scene band designs that use the 'SegHasChanged' variable will now show the segment details when the scene band is re-displayed at the top of a page.
  • Minor bug fix for macOS light/dark mode switching in the session interface window styled text fields.
  • Fix to allow summary band designs to be imported from external settings files.
Mark Franken, MPSE
Old 06-21-2020, 11:01 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.2.1. This version includes the following updates:
  • New filter field to filter exported ADR cues by their TBW state.
  • While exporting 23.976 and 29.97 FPS movies from the Export Movies window, exports without a watermark now create files at the correct frame rate.
  • Fix for macOS 10.10 -> 10.13.6 users so a preview is shown in the Export Movies - Watermark Setup window.
  • Bug fix to stop crash when data is loaded after the Export Movies window has been opened and closed in dark mode.
Mark Franken, MPSE
Old 02-03-2021, 04:29 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v3.3.0. This version includes the following updates:
  • New production property to allow Custom Cue Numbers (CCNs) to work with character based cue numbers.
  • New 'Files to Export' checkbox to allow export of the TBW list as a Text or Excel file.
  • New Session Interface window settings menu options to set which fields are cleared when the 'Clear All' button is clicked.
  • New field in the PDF shooting script import window to ignore pages that contain the entered text.
  • Bug fix to enable the character cue counter when Pro Tools track names don't contain a character ID.
  • Bug fix so selections made in drop-down menus of the PDF Layout lists work for Windows builds.
  • Updated messaging after an AAF file export when the frame rate equals 23.976, 29.97, 47.952 or 59.94 to work-around Pro Tools load issues.
  • Fix to Band Designer Formula Editor window so that quotes aren't entered as smart (curly) quotes and cause errors.
  • Additional bug fixes and enhancements.
Mark Franken, MPSE
[IMG] code is Off
EdiCue v3 - Emmy Award winning ADR cueing app major update has been released mfranken Partner Announcements 0 08-04-2019 09:16 PM
12.6 released!!! thanos4 Pro Tools 12 80 09-30-2016 08:13 AM
12.5.2 released MIKEROPHONICS Post - Surround - Video 5 07-09-2016 10:36 AM
Will 6.7 be released on Oct. 28? Imagine Pro Tools TDM Systems (Mac) 15 10-27-2004 01:03 AM
DP 4.5 Released! Imagine Pro Tools TDM Systems (Mac) 11 10-01-2004 04:42 AM
