Old 05-06-2011, 04:08 PM
baconpatroller baconpatroller is offline
Default How to shorten a wav loop
I have a loop that is 5.334 seconds long. How can I shorten it to 5.333 seconds? This is simplicity itself in the program I used to use but I can't figure it out in PT.
Old 05-06-2011, 06:37 PM
Top Jimmy's Avatar
Default Re: How to shorten a wav loop
Do you actually want to time compress .001 second, or do you want to lop off (edit) .001 second?
Time compress would make the loop .001 second faster. Editing would cut .001 second off of the loop.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 05-06-2011, 07:55 PM
A little deeper explanation of the goal might help here. Is this a rhythmic thing? If so, then I might go into GRID mode, enable Elastic Audio(with the proper algorithm for the loop) and grab the end of the loop so it snaps to the grid.
Old 05-07-2011, 09:56 AM
The difference is so small that either one is ok. In my old program I just lop off .001 but compressing would work just as good for my purposes.
Old 05-07-2011, 09:58 AM
I just want to shorten the loop so that all the loops I use on a track are the same length and I can just start them all at the beginning in different tracks, repeat them like 40 times, then cut out the ones I don't want and still have them all still in time after they have been repeated 40 times.
Old 05-08-2011, 07:42 PM
Top Jimmy's Avatar
In that case, I would align the loops vertically on their own tracks, enable the all editing group, using the trim tool edit some off of the end of the longest loop (all the loops will get edited), again with the trim tool drag the end back out on one of the loops with the exact length that you want. Now all of the regions will be exactly the same length.
James Cadwallader
Shorten Song WaddyP Pro Tools 10 6 07-14-2013 01:32 PM
how do i shorten my song sethwudel Pro Tools 10 5 12-28-2012 05:41 AM
Can't Shorten song rjh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-06-2010 09:14 PM
How to shorten a session? Patrick Jackman Tips & Tricks 7 09-19-2004 03:21 PM
How to shorten a session? REtroJECT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-18-2003 01:54 PM
