Pro tools 10 HD Native Thunderbolt -9171 and -9129 errors after trashing prefs
Hi all. I have a 2012 Mac mini with a 2.6 Ghz intel Core i7, 16GBs of ram running
OS X 10.8.5 with PT 10.3.9 On a whim I decided to trash preferences and databases to see if I could improve my system performance. After doing this and rebooting, I am getting error messages when I initiate playback. This happens in pre-existing and brand new sessions... "Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue. If this occurs often, verify your sync cables or try changing the HW Buffer Size setting in the Playback Engine dialog. In most cases a larger HW buffer size will prevent the problem." Nothing has changed with my clocking situation so the only thing that makes sense is that I have caused this problem by trashing prefs etc... Anyone else out there experienced this/have a solution? I have tried to increase my buffer/change number of processors/cpu% etc. Nothing helps. Thinking I should do a safe uninstall/reinstall of PT... Thoughts? In a real bind. Vocals tomorrow at 11am. Thanks!!! Pat |
Re: Pro tools 10 HD Native Thunderbolt -9171 and -9129 errors after trashing prefs
I have the same issue using PT 10.3.8 and also sometimes on PT 11 - Im running a iMAC OSX 10.9.5 - 32 GB RAM ( I know only PT 11 can use more since its 64bit) 2.4 Ghz Intel Core i7 with 2TB built in ... All avid support tells me is "my mac & osx isn't certified by avid and they cannot help me" A little frustrating when they only support an OS 4 versions OLD! Everything worked fine for years so i know my mac had plenty of power to run a session and the OSX was fine, just can't uninstall pro tools which i won't anyway. I had less issues with a windows laptop with 4 gb of memory and same size sessions
It seems ever since i upgraded to the thunderbolt native HD Omni, from the mbox 3 i had clocking issues/errors. Not sure if i need an external clock, but i think an HD OMNI's internal clock can do the same thing an mbox 3 did. it happens randomly but VERY OFTEN in larger sessions with more tracks/plugins. Sometimes until the track no longer plays and I get an error every time i hit play on the keyboard. Then i have to start inactivating and mixing in batches. I wish i can move to PT 11 to reduce this but the amount of money i spent on RTAS plugins that don't have free AAX upgrades is just not worth switching yet for mixing. AVID PLEASE ASSIST? |
What is your Playback Engine? Pro Tools Aggregate I/O?
Hd native thunderbolt (Avid Omni via thunderbolt)
Do these errors persist at the largest hardware buffer size? Are you using any plug-ins by Native Instruments?
Yes even at the highest buffer, I tried changing processors, and yes I use native instruments plugins such as kontakt, battery ect..
Try removing those plug-ins from the plug-ins folder (move to Unused) and see if the situation improves.
So far I did the following and same 9129 error: Removed all native instruments AAX and DPM plugins to unused Removed any duplicate plugins that had either AAX or DPM to unused My Session is always set to copy files on import so they get stored in audio folder (not sure if this is related but wanted to mention) Tried different Buffer size Tried different Processor # Tried to increase cache Made sure sample rate conversion is on , on the OMNI (since error mentioned clocking issue) And just to note the session I am testing has NO native instrument plugins being used. Plus error occurs almost everytime I try to audition tracks through the workspace browser. I am giving up and ready to return all the avid HD equiptment I purchased for the UA quad. So much money and I can't even run a session already had to cancel 2 clients and its costing me money. Please escalate this where needed to offer a viable solution. Thank you |
And you have done the PRAM reset as it works sometimes.
Also see if that helps, otherwise try swapping the PCIe card to another seat and see if that solves the issues. I had our native pcie card in the third and forth slot and in the third it was better.
Yes did PRAM and SMC reset. Also I do not use PCI slots I have a thunderbolt HD native avid Omni and yes I tried switching to another thinderbolt port. Same errors
Pro Tools 11.3.1 Error Codes -9171 -9172 -9173 -9129 -9093 | priyatsomo | Pro Tools HDX & HD Native Systems (Mac) | 11 | 02-27-2015 06:23 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
Constant error 9171 & 9129 Pro Tools 10.3.2 | jsdetoro | macOS | 14 | 12-18-2012 07:57 PM |
-9129 Errors: How many of you are using UAD-2 with PT Native? | tclash | Pro Tools HDX & HD Native Systems (Mac) | 2 | 12-17-2012 05:02 PM |
HD Native -9129 errors | KMcK | Pro Tools TDM Systems (Mac) | 0 | 03-16-2011 03:31 PM |
