Time adjuster plugins
Why does the time adjuster plugin only work in delay or one direction.
For example what if i got 10 tracks and one of them had a plug that causes delay, then i have to put the time adjuster plugs on the other 9 tracks instead of putting just the one on the plug in question. Is just another slap on the face for le users or am i missing something? Thanks guys. |
Re: Time adjuster plugins
Probably because the time adjuster is designed to move tracks later to match latency of other tracks. Instead of using that plugin, try nudging your 1 track forward or experiment with you choices to find plugins that have no latency whenever possible.
Thanks for the tip.
Say i got a plug with 64 samples delay and the buffer is set above this number does the pt buffer compensate? Cheers |
You could nudge as already mentioned, or bus the tracks to an aux and apply the time adjuster there. |
alt+h guys....answer to all ur delay comp probs...
Time Adjuster plugins NOT working on Instrument Tracks! | Horea | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-07-2008 06:02 PM |
Time Adjuster | KamilFX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 02-13-2006 12:16 PM |
Time Adjuster for PT LE ? | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-09-2006 02:37 AM |
Time Adjuster | 1511 | Tips & Tricks | 1 | 03-24-2004 03:18 PM |
Best way to Use Time Adjuster | carlone | Pro Tools TDM Systems (Mac) | 4 | 07-20-2001 12:07 AM |
