Old 04-20-2021, 01:10 PM
resonatee resonatee is offline
Default Re: Metering Delay / Metering is Late
Yeah i see the problem is real. Cannot reproduce it here on cMP / Mojave with 2021.3.1. Did you contact Avid support?
Old 04-20-2021, 05:43 PM
Spanzor Spanzor is offline
Yes I have a ticket open at the moment, we've been corresponding most of the day. Try loading up your master bus with a bunch of heavies (like 10 Ozone's for example) and see if you can reproduce.
Old 04-20-2021, 06:20 PM
Does it happen without plugins on master fader? If plugin latency goes over ADC limit these things may happen.
Old 04-20-2021, 07:25 PM
May or do?
Big difference here as it wasn’t happening before this update.
Also, in my opinion, if that is the case, that’s a bs argument/reason/excuse whatever you want to call it. Fix it!
Accurate metering should be a no brainer for the “industry standard” software.
I’m starting to wonder just what industry we’re even talking about anymore.
Are you sure it’s not my computer monitor latency?
Old 04-20-2021, 07:34 PM
Is that so much to ask, that my metering is accurate?
If plug-in latency causes this then why doesn’t the gain reduction meter show up late as well? Why the inconsistency?
Why do the drum meters show up in time with the music- only the master fader meter is late.
I’m so done with pro tools. I’m tired of Avid being “infallible” in their useless explanations of simple problems that make no logical sense.
If it “may” cause this problem, then fix it. Make it better. Strive to push your limits. I don’t write the code, I make the records.
Old 04-21-2021, 02:27 AM
Yes, the metering is late as soon as i add heavy (izotope) plugins that require compensation on a master. But in my workflow, i do not really use master faders. And anyway, it sounds good. So that is my five cents, use it for whatever it is worth to you.
Old 04-21-2021, 02:50 AM
I think you found your reason then. Ask iZotope to fix the plugin and it should be good again.
Old 04-21-2021, 04:47 AM
Sure let me just start hitting up devs in my free time.
It's not just with isotope, that's simply one example of a plugin. Happens with Fab Filter stuff too...any heavies really
You can delete my account here.
Old 04-21-2021, 05:46 AM
You can update your plugins. I have only seen this very rarely and every time it has been some plugin needing update. PT does not need to be fixed, just trying to help you find your problem plugin. And the shortlist is on your master fader.
PT 11 Metering Bug? mrjohn Pro Tools 11 3 06-23-2013 07:32 AM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 07:33 PM
metering? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-28-2007 02:20 PM
5.1 metering mrkite Pro Tools TDM Systems (Mac) 6 05-17-2004 06:51 PM
Metering Nika Pro Tools TDM Systems (Mac) 11 07-28-2003 09:16 AM
