#441
Re: I Got Pro Tools 7.3 to recognize 2.7GB of memory- Here's how
Usually at 64 but if the session starts to grow way big and I have to go back in I will usually move to 128. I mix at 128 unless I get errors to remind me to move it up. I never need to go above 256, ever. Usually the only thing that pushes me to 256 is Waves plug-ins will throw an error in 128 when their GUI is activated unless I do it in stop mode (big session 50+ tracks lots of VIs and plugs).
#442
Hey Scar, glad u got it goin now!!! I'll take a listen to ur fun piece in the morn; I blew my speakers on my laptop so I can't listen to Naethen
OK now I'm finna watch C.M. MC
#443
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
#444
When you blew your speakers did you just blow too hard?..... Couldn't pass that one up. I am now back in my good mood
#445
#446
#447
#448
Hey thanks for this, I finally had the guts to try this 3GB thing out.
i7 Bloomfield / Asus PT6 / PTLE 7.4 / 002R under construction here. My Dverb-test let me put 20 more Dverbs (four more auxes ) after doing this switch / patch. I haven´t optimized anything in XP yet, BIOS is default... , no OC... now I get 420 Dverbs 24/48. Runs really smooooth.... stunning. One question: I send the test tone to all the recording tracks plus the auxes so every Dverb is actually doing some work. The track count gets quite a bit higher if I only play the tone on one track. Which way is correct?
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
#449
Can this be done in Windows 7?
#450
WOW....this brings up lots of memorys.....
Not that i know of or have seen. xp only. the best way now is to just go to W7 64 bit.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Pro tools 8 doesn't recognize 192 i/o | supafuzz | macOS | 8 | 01-14-2014 08:12 AM |
Pro Tools HD 9 Doesn't Recognize 2nd 192 io | oechols | Pro Tools 9 | 2 | 05-09-2011 06:18 AM |
Pro Tools can't recognize 192 I/O | Juraj Bernáth | Pro Tools TDM Systems (Mac) | 5 | 11-03-2010 08:46 AM |
Pro Tools LE does not recognize more than 1 CPU | done_411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-22-2010 06:32 AM |
Pro Tools Does Not Recognize M Box | beelofi | Pro Tools M-Powered (Win) | 3 | 01-15-2007 10:21 AM |
