6101 error
Hi guys!
I have been getting this error for a few months now so I decided to get a newer computer. I recently got a new (used but new to me) 2010 Mac Book Pro, 2.4 ghz, dual core, 4 gigs of ram, and 500 gig hard drive. I have it partitioned running os snow leopard for Pro Tools and Yosemite for normal computer use. I have been getting this error prior to this setup and want to know whats causing it. I should also note that I simply cloned the hard drive of my old mac and installed the cloned drive in my new (new to me) 2010 mac book pro. My Pro Tools rig is 10.3.10 M - Audio C400 - 1.0.5 drivers Here's what I've tried so. I have removed all plugins and put them in the unused folder - no change I have played around with the h/w buffer - the best setting is 256 samples, 1 processor, 80 % usage, delay comp short, plugin buffer level 2. *should I have it set to 1 processor or 2? I have gone through all the optimizations recommended on the avid site for snow leopard. What else do you recommend? |
Re: 6101 error
Try it both ways and see what happens.
Re: 6101 error
Not sure when Apple started using Fusion drives, but if you have one, that could be an issue Do you have a separate recording drive?
Re: 6101 error
Hi ernie
For what it's worth I'd try doing a clean install from scratch. Are you disabling wifi when you run ProTools? I've found that helps. let us know how it goes, dave |
Re: 6101 error
Quote Albee: Do you have a separate recording drive?
Re: 6101 error
I wasn't recording with a separate drive.
Never knew you where supposed too. I tried it today and recorded 30 minutes with no errors. I'll let you know how it goes. Thanks. |
PT 9 -6101 error | Fritz | macOS | 5 | 05-18-2014 04:59 AM |
Error -6101 in PT 10 | Cutlerbri | Pro Tools 10 | 5 | 03-18-2014 02:08 PM |
error -6101 | PMcC | macOS | 3 | 02-15-2012 02:47 PM |
CPU Error (-6101) | Connor | macOS | 9 | 01-31-2012 03:43 AM |
PT MP 9 6101 Error | DR Music | Pro Tools M-Powered (Mac) | 0 | 11-12-2011 03:46 PM |
