Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 10-21-2018, 11:40 PM
CalebT CalebT is offline
Default Change the input and keep the output?
Is it possible to change the input to my audio interface and then have the output as my computer? Because i cant listen to what i have recorded or monitor it cause i cant hear it. I cant use my interface as an output because my headphone jack isn't the right size and i haven't purchased an adapter yet. So the only possible way to hear it is to have the output as my computer so i can plug in my headphones into my computer to hear it. The problem is whenever i change my input to my audio interface it automatically changes my output to and wont let me put my computer as the output unless i use the computer as the input. I dont know what to do. Does anyone have any suggestions? thanks!
Old 10-21-2018, 11:51 PM
BScout BScout is offline
Default Re: Change the input and keep the output?
No.
If you are on a Mac, you can create an aggregate device using both audio interfaces and make them one.
The other idea is you send the output of your audio interface back into the input of your computer's built-in audio and then you can loop back to using the computer's headphone out.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 10-22-2018, 04:17 AM
Im on a PC.
and So its not possible to have seperate inputs to outputs? And how do you do the loop thingy you mentioned? Thanks!
Old 10-22-2018, 10:00 AM
Originally Posted by CalebT View Post
Im on a PC.
You're going to need a real interface for this
Old 10-22-2018, 12:20 PM
If that didn't make sense to you, I guarantee it'll be cheaper and easier to get a headphone jack adapter and skip all this.
Old 10-23-2018, 12:39 AM
Sardi Sardi is online now
Hahahaha!!
Probably like a 5 min trip to a shop and a $2 purchase.
WOWZERS!
Old 10-24-2018, 01:21 AM
i do have a real interface. And i live in cambodia so its not that easy to find a headphone jack adapter... ive looked around and havnt found one.
Can't change my default output bus Talisker macOS 3 01-11-2012 05:18 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 02:08 PM
Eleven Rack doesn't change sound output when I change to a new rig Jlambton Eleven Rack 4 03-01-2011 12:51 AM
Shortcut to change output Studio Studio Pro Tools TDM Systems (Mac) 4 03-15-2007 07:51 AM
How to change the I/O settings??? (Output) joeytpg Pro Tools M-Powered (Mac) 3 01-17-2006 12:06 PM
