Detection of Stereo/Mono Track in AAF Import
Hi guys,
I have been reading the forums frequently in the past year but this is the first time I have decided to start a thread because I have been totally stumped by this problem. I am currently working on this small project and the editor is using a NLE called Edius 6 by Grass Valley. When obtaining the AAF for the audio mix, I have selected the options in Edius to copy source files (interleaved stereo) together with the AAF in a folder. However, when I open the AAF in Pro Tools, the AAF import dialogue box detects the tracks as mono. So for example if I had two stereo tracks in the NLE, Pro Tools would create two mono tracks only. It also discards one side of the stereo file rather than create a mono sum. Interestingly, Edius can also export AAF with Pan settings and this creates an AAF with split mono tracks. However, as the source files are still interleaved stereo files, Pro Tools is also unable to relink the split mono tracks to the interleaved stereo files. I am wondering if there is a way to force Pro Tools to recognise the tracks as stereo tracks or a better workflow solution to the problem. Thanks in advance! |
Re: Detection of Stereo/Mono Track in AAF Import
Have you had any luck getting Edius AAF files to import to PT? If so please post how you did it. I am also trying to get Edius sessions in to PT.
Thanks Scott
Scott Auckland New Zealand PT2022.5 Focusright RedNET 8Pre, RedNET R1 Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit |
Have you tried opening a new PT session setup to have stereo and mono tracks the same as your Edius timeline Then using Import session data from the AAF linking known stereo tracks from Edius to stereo tracks in your new empty PT session? Andrew |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
Mono / stereo bulk file detection | idris | General Discussion | 0 | 08-13-2007 06:59 AM |
What do i import a "dual mono" audio file as??? mono or split stereo? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-17-2002 04:02 AM |
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 06-26-2002 03:21 PM |
can you not copy automation data from a mono track to a stereo track? | Felix | Tips & Tricks | 5 | 04-09-2002 06:32 PM |
