Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 04-08-2012, 03:46 PM
S-ACU S-ACU is offline
Default SC48 and SSD
Hello, I know that the hard drive in SC48 is safe and no problem, but anyone has tried to install an SSD?
Old 04-09-2012, 01:27 PM
Tim McCullcoh Tim McCullcoh is offline
Default Re: SC48 and SSD
We've replaced one hard drive in our SC48, at about 6 months of age.
IIRC, Sheldon mentioned elsewhere that solid state drives are not yet supported by AVID in the SC48, although they are in other Venue products. Do I recall that correctly, Sheldon?
Old 04-09-2012, 03:44 PM
Thanks for your reply Tim, I hope that will be possible, in our work we need the maximum reliability.
Old 04-19-2012, 11:33 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Hi guys,
There isn't an official recommendation for SSD, but customers who have chosen to replace their HDs with SSDs report that they work well. So use at your own risk.
Main points to consider are capacity (16 GB or higher) and read/write access time (usually not a problem due to SSDs faster speeds).
Sheldon
Old 04-20-2012, 05:56 AM
Thanks for your reply Sheldon, can anyone suggest the best model to replace?
Old 04-21-2012, 02:54 PM
Voice Of Truth Voice Of Truth is offline
I suggest not buying OCZ drives - I had a drive controller failure and it's quite common. One day you power on your system and find that SSD is simply dead - brilliant for live sound.
Google for drives with reliable controllers - this should be a good starting point.
Old 04-22-2012, 09:55 AM
I am deciding which SSD to get, Intel SSD 120Gb 520 is one option, is compatible with SC48?
Help please
Old 04-22-2012, 10:02 AM
Greg C Greg C is offline
Any SATA interface drive should be compatible. The issue is reliability. Focus your research on that.
Cameron Pro Audio
Exclusively at the Miners Foundry
Old 05-04-2012, 07:56 AM
I finally installed the SSD Crucial M4 with 128 GB Sata 3. everything works perfectly and the start is 10 seconds approximately faster.
thanks guys for your help
SC48 to DP or other DAW? brookfloyd VENUE Live Sound Systems 1 08-03-2013 12:42 PM
Sc48 fwx pt9 lmiller VENUE Live Sound Systems 3 03-18-2013 04:39 AM
GPI on SC48 TheMAXX7 VENUE Live Sound Systems 3 03-18-2012 01:11 PM
SC48 into a 5D, Help! J2sound VENUE Live Sound Systems 6 03-03-2011 05:56 AM
Sc48+pt le braxty VENUE Live Sound Systems 4 04-19-2010 12:00 AM
