Old 03-24-2015, 07:26 PM
diegomixes47 diegomixes47 is offline
Default AVID Artist Mix
From all the posts here about the Artist Mix I get a bad feeling. I'm planning on buying one, but it seems to have a lot of problems running on Yosemite.
What's your advice? Is it possible to run it without having EuCon problems or hardware failure?
Old 03-25-2015, 01:52 AM
thewiz's Avatar
thewiz thewiz is offline
Default Re: AVID Artist Mix
It working on my system without any big problems. MacBook Pro 2012 with Yosemite
Old 03-25-2015, 03:10 AM
Southsidemusic's Avatar
Is Eucon working with Yosemite now as it has been a stick up the **s to get that working so if it works now i say go for it, we have 4 units working great with Mavericks and 10.8.5 but not working in 10.10
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-25-2015, 12:58 PM
I'm running Pro Tools 11.3.0. I haven't upgraded to 11.3.1 because I heard it's not working that well.
In regards to the Artist Mix, I just want to be sure that I can hook it up and run it smoothly with my current setup, OSX Yosemite 10.10.20 and Pro Tools 11.3.0.
Old 03-25-2015, 02:44 PM
hanksinclair hanksinclair is offline
I own 2 Artist Mixes, 1 Artist Control and 1 MC Transport. Everything working fine under Yosemite and Logic 10.1.
Old 03-28-2015, 01:29 AM
ilovemyssl ilovemyssl is offline
DON'T BUY ONE!
At least not if you're using Pro Tools 11.3.1 / Mac OS 10.9.5
I have the latest drivers / firmware / Pro Tools 11 updates and it does not work for more than 20 or so minutes before going offline and requiring a full reboot (computer and control surface)..
Also, I'm on my 3rd one in less than 2 years if that says anything about the build quality.
Avid are VERY aware of a design fault in the circuit board with the power circuit, and SHOULD have done a full recall on EVERY UNIT EVER SOLD and fixed the problem.
But of course they are too money hungry to do that so unless you lean on them hard they will charge you $$$$$$ to fix it.
So now you know.
Also, I've heard the S3 is just a glorified version of the Artist Mix and suffers from a lot of the same issues as the Artist Mix.
Time will tell.
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 03-28-2015, 01:45 AM
thewiz's Avatar
I've had mine little over a year now without any big problems, used it on PT10,11 and now 12. MacBook Pro 2012 and now Yosemite.
Old 03-28-2015, 03:48 AM
CME CME is offline
I had one a while back. When it worked it was great. But if you get one you definitely need to find a combination (OS, PT, Eucon version) that works and stick with it. I finally had a pretty solid set-up. Sold it for financial reasons more than functionality reasons.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 03-28-2015, 05:03 PM
Manu101 Manu101 is offline
2x euphonix mc mix and one euphonix transport here running on a "definitely not suported" Hackintosh with Yosemite. Pretty stable with an unmanaged switch connected via a separate ethernet port (from my main router).
Manu
PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup
Old 03-29-2015, 12:16 PM
eesn eesn is offline
please share your config in more detail?
Avid artist mix!! help please baybadness Artist Series 3 09-14-2014 03:37 AM
FS: Avid Artist Mix Chingy Buy & Sell 1 02-19-2014 07:49 AM
AVID Comes through on my Artist Mix ArKay99 Artist Series 2 02-03-2013 02:52 PM
FS Avid Artist Mix Like New tomhartman Buy & Sell 2 10-27-2012 10:21 AM
FS: Avid Artist Mix jeffinaustin Buy & Sell 1 06-25-2012 09:19 PM
