Pro Tools 10 will not open properly
I am using Pro Tools 10 on a i-mac os 10.7.3 with 8 gig of ram Lion operating system.
I get the following message. Could not create a new document because assertion in volume development ws.ludwig/Alturaports/dfx/macBuild../view/uMenu.macOS.mm/line 1350. Also when trying open a recent session get the error that pro tools playback engine does not support 44.1khz. I tried several fixes from things posted on forums, which included: repairing permissions, re-installing drivers, checking cable connection to mbox2 pro interface, re-booting. Also tried the fix below: v-Delete the "Digidesign Databases" folders on the first level of all mounted hard drives. -Delete the "Volumes" folder: Pro Tools versions 7.3 and earlier it's located in MacHD > Library > Application Support > Digidesign > Databases. Pro Tools 7.4 and higher will find it in MacHD > Library > Application Support > Digidesign > Databases > Unicode. No Digidesign folder was found under application support. Also, is Pro-Tools 10 compatible with BFD drums software. It used to be include as a bundle with Pro-Tools 7. Any help would be appreciated. |
Re: Pro Tools 10 will not open properly
I am on PT 10.0.1 running Mac Snow leopard and I got the same error.
Try, as dumb as this sounds, changing your playback engine in the setup menu to built in output. I just had the same error and it fixed it. Don't try to launch a new session. Simply launch PT, close all error dialog prompts , and change the playback engine. Hope this helps. |
UGH - Pro Tools never seems to work properly... CPU overload | cdbboyce | macOS | 5 | 05-16-2012 08:30 AM |
Can't get my pro tools le 8.05 working properly | rockposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-05-2011 12:27 PM |
Pro Tools 8.0.5 updater not downloading properly. | carbonism | Pro Tools M-Powered (Win) | 0 | 03-16-2011 04:51 PM |
How do I synch the Triton to Pro Tools Properly? | HB1978 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-08-2009 10:16 PM |
How to properly open a session recorded on another computer | Luckyjason4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-30-2008 01:09 PM |
