Mystery of the Slowing Edit Solved
The problem I've been having, where as I edit - even a simple one track voice over - ProTools slows down to a crawl and eventually stops. Sometimes I'd get the beachball for 30 seconds to a couple of minutes. Sometimes it would just hang. I happened to noticed that the newly created regions all the sudden had a suffix of -15000 or -37000. I turned on the option to display auto-created regions and it showed that I had created some 50,000(!) regions while editing a ten minute voice over that had maybe 15 edits. The problem is the "Separated Regions Operates On All Related Takes" option. Unchecking it solved the issue. I assumed that it only worked on takes that were loop recorded but I was clearly wrong. I know others have complained about the edit slowing down and I recommend you verify that setting.
T http://www.cafepress.com/audioshirts |
Re: Mystery of the Slowing Edit Solved
Pero, What version meng?
7.4 or 8?
Ray Trujillo Freelance Audio Engineer |
8.0 Papí. I never had the problem with 7.4.
Say hi to the crew! T |
SOLVED>>Need HELP, SUPER ASAP.< |
audioindo | Pro Tools TDM Systems (Mac) | 18 | 04-21-2007 05:43 AM |
g5 slowing down! | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-21-2004 11:43 PM |
Second HDD for PT project storage..mystery solved | Jeff Laurence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-11-2004 06:29 PM |
Seems like PT is slowing down... | Dr. J | Pro Tools TDM Systems (Mac) | 10 | 07-16-2002 06:21 PM |
ID 1103 Mystery Solved | Digivan | Pro Tools TDM Systems (Win) | 1 | 04-24-2002 09:01 PM |
