Default patch settings? Drag & Drop replace sample?
1) Is there a way to save a default patch or part, meaning the parameters? I'd like every new patch (created by drag & drop from the PT tracks) to start with a default release time (among other settings).
2) Is there a way to drag & drop replace a sample? In the event #1 can't be done, I could save a default patch & then replace the sample (undesireable workaround, but better than nothing). I see a menu option to replace a sample but it forces me into dialog box & I should be able to drop a region off the PT tracks & replace that sample, therefore keeping any settings I've made. |
Re: Default patch settings? Drag & Drop replace sample?
You could drag & drop directly on to the Part in the Treeview Section - (Import samples to...), thus retaining global (Patch) settings.
And you can drag & drop on existing Patch Modules within the Patch List retaining patch settings. This is destructive however. filosofem
Aaron Mulqueen - 001 HD Native |
This is for drag-n-drop of course. |
I steered you wrong, use 'Paste Part Parameters', right-click Part List (Patch List) - Copy Part.
filosofem
Even if I can get this working, it's unreal that something this basic should be so cumbersome. Believe it or not I was on the beta team, but never really got around to testing it thoroughly because of shortcomings like this. What looks like a wonderful sampler for music, is one crucial step away from being usable in a sound design environment. While yes, it can still serve as a sound design sampler, someone needs to come watch me work for a day to see how 98% of us in Sound Design need to use this. Drag & Drop into a default "Instrument", is what we need. Without that, the workflow just isn't there & this will be a plug-in that we never bother opening. I'll take just drag & drop replacing a sample - it's easy enough to save a patch, and call it up. Looks like it's all in there, with the "Replace Sample" option, but navigating to a folder for that isn't what we're after. Just missing one step DIGI - drag & drop replace a sample - please! |
Just to confirm:
*Patch List>Sine Patch Module>Expand Part List - select Sampler>Sampler Part Filter Parameter Sub-Page - adjust Release. *Right-click Sampler Part Sine>Copy Part. *Drag & drop region into Sine Patch Module Part List>right-click newly dropped Sampler Part>Paste Part Parameters. Ummm... with the 'Replace Samples' command, could you not use 'Favorites' (Browser Controls) in the 'select new audio file' dialog? filosofem
They're so close - yet so far. |
A simple modifier would suffice for Replace Samples e.g., Shift - drag & drop. Sorry I can't be of any more help, I totally understand your frustration, maybe one day you can blow the dust off thee old girl. filosofem
Thanks again for the tips! At least it wasn't for a lack of looking.
I'll just have to go back to Kontakt until DIGI makes it a usable workflow. |
Drag and Drop Sample Conversion Quality | Numi | Pro Tools 10 | 2 | 11-09-2011 10:19 PM |
sample rate conversion and drag and drop issues | jafbox | macOS | 6 | 01-10-2011 08:25 AM |
Structure - next patch or only drag/drop? | andrewpiano | Virtual Instruments | 5 | 05-18-2010 07:14 PM |
Drag & replace a sample in structure? | Farmer Dave | Virtual Instruments | 22 | 05-19-2009 10:26 AM |
Drag and drop from desktop and sample rate convert! what? | crizdee | Pro Tools TDM Systems (Mac) | 7 | 04-14-2008 09:59 AM |
