Old 05-09-2007, 10:37 AM
Halstein Halstein is offline
Default How to apply fade-ins and fade-outs on selected regions?
Here's the case: I got 200 regions (when I'm finished...) of small trimmed snipplets of voiceovers. To smooth them out, I want to apply a 10ms fade-in and a 100ms fade-out on all selected regions - in ONE GO! I looked up in the manual, but did not (AGAIN!!) find a solution. Automatic fades are not written to disk, so I believe that could be a problem when I export each region as files - and the fades are not included. Anyone?
pthd9-pt11
imac 14,1 / imac 7,1 / macbook air 5,2 / self-built hackintosh with gigabyte z97x board + quad i7-4690
Old 05-09-2007, 11:32 AM
Ale Ale is offline
Default Re: How to apply fade-ins and fade-outs on selected regions?
Hi
Normally it is not possible
BUT:
You can do a little trick in the fade window
I always do this trick when the other fades don´t work
In your case:
Do a selection over all regions
Open fade window and adjust the fade length to 100ms
Now adjust link to none (unlink fade in and out)
Now you can see the little quarters at the fade start and end points.
Drag those little quarters and adjust the fades in and out points as desired.
You can move all 4 points an make create special fades
With this way you can have 10 ms fadein and 200 ms fadeout lenght.
But:
The rendered fades will always have 100ms, even the very 10ms in fade
It looks weird but it works. I you want to see better what you have done you must open the fade window again
Hope this helps
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 05-09-2007, 03:07 PM
Hi Ale.
I did a 20ms batch fade on both in and out, and the result was satifying. Thanks for the explanation.
pthd9-pt11
Fade in and outs on several regions all at once Raoul23 Tips & Tricks 2 10-25-2011 10:07 AM
Fade ins and outs Boe Larsen Pro Tools TDM Systems (Mac) 3 07-13-2011 07:03 AM
Fade-In and Fade-Out on Multiple Disjoint Regions holden Pro Tools TDM Systems (Mac) 2 11-30-2007 01:22 PM
Fade in and Fade out on multiple regions? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-03-2006 11:07 AM
Fade outs... graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-27-2003 09:35 PM
