Adat In on 192 doesn´t work
Hi there!
I have a HD3 System with 3 192. I connected an adat bridge to each 192 to get enough Outputs to my DM2000. Sometimes I also want to use the Adat Input on the 192 and adat bridges to record direct from the DM2000. But I can´t get signal to the Adat In on the 192. But with the old Adat bridges everything works fine. Looks like the 192 doesn´t accept the incomming adat signal. Is possibly the distance to long? Please help! |
Re: Adat In on 192 doesn´t work
Have you assigned it in Hardware Setup?
Yes I did!
Also the I/O routing is done proper. And as I wrote; everthing works fine with the adat bridges. Even if I use the same lithpipe |
Like I tought the lenght of the lightpipe cables is to long in my studio. 192 seems to be very sensitiv in receiving digital signals. At least more than a adat bridge. |
My legacyinterface doesn´t work! | matsgranberg | General Discussion | 0 | 07-24-2005 09:27 AM |
My two day 002 doesn´t work already!!! | Punkest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-29-2003 10:07 AM |
HELP! My MIDI IN doesn’ work. | TOMMA | MIDI | 9 | 04-12-2002 12:29 AM |
It doesn`t work - on 3 different PC´s | schrodis | Digidesign Hardware & Software | 7 | 11-09-2000 10:09 AM |
3 interfaces doesn´t work with mix plus?? | stefan. | Pro Tools TDM Systems (Mac) | 3 | 11-09-1999 08:35 AM |
