ID 1103 Mystery Solved
Hello Everyone,
Well i found out that if you have digigain wav drivers installed so that you can run wavelab or other editors through your Protools interfaces you will get the 1103 error at random and have to restart your computer. I believe it is due to the drivers trying to run as your Protools drivers are trying at the same time and Prottools cannot aquire hardware. So i unistalled them and the system has not errored one time. My new question is how do i fix this because i love using Wavelab 3 for Making CDs and so on. Thanks Van |
Re: ID 1103 Mystery Solved
Notice that to use Protools TDM hardware with the wav driver, it is not necessary to install the Digigain accessory, which is just a volume control accessory. It may be that it will all run fine by just leaving out the Digigain part.
Mine works fine, and I use Sonic Foundry's Vegas Video to burn with. You might try it, if you can't get Wavelab to work. Vegas includes the functions from the famous but discontinued CD Architect, and is by far the simplest CD burning program I have ever seen. I spent 10 minutes showing it to a singer, who has never touched a computer music program, and he then track edited a two hour live recording of a show he was in without having to ask a single question about the program.
steve Your Heaven |
Digitest error -1103 | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 20 | 01-07-2014 04:53 AM |
Mystery of the Slowing Edit Solved | TLarvenz | Pro Tools TDM Systems (Mac) | 2 | 05-06-2009 07:24 PM |
error -1103 | cbcarch | Pro Tools TDM Systems (Win) | 0 | 01-03-2008 10:17 AM |
Second HDD for PT project storage..mystery solved | Jeff Laurence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-11-2004 06:29 PM |
message ID=-1103 error | polkbrosmusic | Pro Tools TDM Systems (Win) | 1 | 05-15-2001 11:52 AM |
