Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 09-06-2008, 09:46 AM
breaksguy breaksguy is offline
Default Re: Do Lacie Drives have the Oxford Chipset?
Originally Posted by sunburst79 View Post
Kinda way out there but your not trying to stripe the session data across two or more partitions on the same drive are you? You might want to check that all of your session files are in the same partition.
Same goes for writing session files to one partition and pulling samples out of another partition on the same disk.
No I am not striping the session. I am only working with one partition. Each partition has separate purpose. but a good thought and something to keep in mind if I ever DO have samples spread out.
http://www.joekopasek.com
http://www.myspace.com/kopasek
http://www.thebuzzboat.com - use Joe Kopasek as your referral!
Old 09-06-2008, 09:52 AM
Thumbs up Re: Do Lacie Drives have the Oxford Chipset?
Originally Posted by albee1952 View Post
No harm in trying trashing prefs anyway so go for that. I am curious why you chose to partition in 5 parts? The LaCie drives I have are not large enough to warrant partitioning (120-160 gig) so I don't know if that is having any affect. On drives of 200 gig or more, I generally partition in half but that's just a personal preference. I would be using both cores and try running the drive on a firewire 400 port. If you only have a single port, daisychain the drive to the computer and the 003 to the drive passthru. If the drive has no 400 passthru, put the 003 first and try a recording. While this chain is not recommended, it will work for the purpose of testing. Just make sure to dismount the drive before you shut down the 003(the reason DIGI does not like this chain is in case the 003 gets turned off while the drive is writing data, it will corrupt the data). If it records longer, then we know the FW800 port is to blame.
I did what you said and I daisy chained the glyph into the Digi 003 with the Digi 003 connected directly to the computer. and guess what?
it worked. I just completed a 70 minute record session and the only reason it stopped is because I had a 70 minute limit stated in preferences.
Now begins more questions. Why does Pro Tools not want to work with the 800 port? Why am I able to use the SAME 800 port in PEAK and record sessions of a few hours with no problem?
it just doesn't make sense. but at least I found a way to make it work. thanks for your advice.
Old 09-06-2008, 08:34 PM
Glad you made some headway. Firewire 800 has been hit and miss for a few people. I wonder if a different/shorter cable would have any affect on this?
Old 09-09-2008, 09:50 PM
I have never had any luck with 800 to be honest. not even on my powerbook. thing to keep in mind is that if you have a computer with 1 400 and 1 800, they are really sharing the same bus internally.
funny thing...I never got an answer from anyone about the actual topic of the thread!
Does anyone know what chipset Lacie uses?!
thanks
Old 09-10-2008, 10:28 AM
DigiTechSupt's Avatar
I was just going to suggest trying FW400 instead of 800, as we've seen some issues when they're using the same bus - good to know it worked for you.
I partitioned into 5 parts because I learned that DIGI prefers hard drives not over 100 gigs for maximum performance.
I don't know where you heard that, but it's not true. In fact, it can potentially cause more problems than it would ever solve.
As far as I've ever seen, they use Oxford chipsets (911, 912, 922, 924).
Avid Audio Tech Support
Support FAQ
Old 09-10-2008, 02:12 PM
thanks for the bit on chipsets!
Yes, the 400 worked, but only if I daisy chain it through the Digi 003. This is still odd, because essentially I a still sharing the firewire bus...just in a different way. But I get results so I guess problem solved. thanks for all your replies
Old 10-12-2008, 04:30 PM
samplaire's Avatar
samplaire samplaire is offline
In energy saver preference pane try to set the computer performance to 'maximum' or something similar. Hope this helps.
I also found somewhere in the Digi site that iMacs are not good for using the Music Construction Toolkit option of 48 tracks. This (I assume) means not good performance of iMacs. It was some 2 years ago, though. But I can be wrong with the suggestion of your iMac being to blame...
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 10-15-2008, 05:35 PM
yeah, I pretty much blame the iMac right about now. I am working on getting a power mac so I can install extra firewire cards, consider pro tools HD, etc. the iMac's are nice, but I don't feel they are capable to handing a beast like Pro Tools. Other programs work just fine. what can i say, only so much money to spend on [bleep][bleep][bleep][bleep]. thanks for commenting
Old 05-22-2010, 09:59 AM
fridrikur fridrikur is offline
I am sad to say they are not. I bought the Lacie D2 quadra onlinse, in the believe that it was using a TI chipset, but I have now learned that is has the LSI (lugent) chipset. I am disappointet since several sites on the internet stated that the lacie d2 quadra had the TI chipset, even the oxford 911.
Intel(R) Core(TM)2 CPU 6400 @
2.13GHz
Intel Corporation DQ965GF
Memory: 2GB
ST3250310SV 250GB (SATA300, 3.:233GB (H:)
ST3320620AS 320GB (SATA150, 3.:298GB (C:)
External Harddisk: Lacie D2 Quadra 1 TB firewire 400 (Oxford 11 chipset - using a different firewire card than fw410)
Windows System: Microsoft Windows 7 64 bit ultimate
M-audio Firewire 410 (ADS PYRO PCI 64 bit firewire card with Texas instrument chipset)
(6.0.1_5.10.0.5058)
Pro Tools M-powered 8.03
Old 05-22-2010, 03:50 PM
I forgot that I had chosen the legacy firewire control driver, and that is listed as LSI 1394 legacy driver on all my 1394 busses.
So the lacie d2 quadra can still have the oxford chipset. Let us hope so.
Sorry about my mistake.
2.13GHz
Memory: 2GB
(6.0.1_5.10.0.5058)
LaCie HDs feature the Oxford 936 chipset JonesH Pro Tools 9 3 12-23-2010 11:12 AM
where to buy oxford chipset 911 drives (UK) boove Storage Subsystems 19 12-18-2008 06:00 PM
Oxford Chipset Firewire drives s0und80y Post - Surround - Video 4 06-04-2007 06:14 AM
Oxford 924 chipset FW drives M.Brane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-26-2006 10:02 PM
Lacie D2 extreme uses oxford 912 chipset sukks2bu Pro Tools TDM Systems (Mac) 5 01-13-2005 08:21 AM
