Naming of clips when audio file ends with a number
When using an audio file whose name ends with a number, I would like Pro Tools to append a number when I create new clips rather than changing the number. For example, if I have an audio file named "guitar 5-18-13" and I separate it into two clips, I would like the new clips to be named "guitar 5-18-13-1" and "guitar 5-18-13-2" rather than "guitar 5-18-14" and guitar 5-18-15". How can I get Pro Tools to do that?
I've tried unchecking "Auto-Name Separated Clips" but it had no effect on the behavior described above. |
Re: Naming of clips when audio file ends with a number
In PT 10.3.4, if you devide the clip "guitar 5-18-13", it will become "guitar 5-18-13" and "guitar 5-18-14" (not "guitar 5-18-14" and "guitar 5-18-15" as you describe).
If you do not use the "-" (minus) for the last number, but "_" (underscore) or " " (empty space), then "guitar 5-18_13" splitted will become "guitar 5-18_13-01" and "guitar 5-18_13-02".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
If "guitar 5-18-13" is a whole-file-audio, then the split clips will be "guitar 5-18-13" and "guitar 5-18-14".
If, in your case, "guitar 5-18-13" is a part of a mother-whole-file-audio then it works as you described. (Sorry, I did not do my whole homework.) Glad, I learned something and was able to help ! Cheers, Joachim
No, with a whole file it works as I described.
Once clips are split, Strip Silence can rename selected clips in various ways
Although I do like the underscore tip!
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
PT10: Naming & Coloring Clips | TaoMokoda | Windows | 6 | 04-16-2017 08:54 AM |
Importing clips in Pro Tools 10 / clip naming | legasafe | Post - Surround - Video | 3 | 10-20-2012 05:44 AM |
Elastic Audio file/region naming | jem777 | Pro Tools M-Powered (Mac) | 0 | 06-05-2009 04:25 AM |
AUDIO FILE NAMING | vjk | Pro Tools M-Powered (Win) | 2 | 07-13-2007 07:51 PM |
PT/AV XL 5.1 Spotting & naming video clips | Robin Hollings | Post - Surround - Video | 0 | 05-07-2001 04:23 PM |
