MIDI PROBLEMS - DIGI PLEASE HELP!!
SETUP:
MIX CORE ADAT BRIDGE 24 PT 5.1.3 G4 400 / 1GIG RAM 40 GIG IDE / 30 GIG IDE / 10 GIG IDE STEALTH SERIAL OPCODE STUDIO 4 PROBLEM 1: Sometimes when I try to insert a midi note on a midi track, the note appears when I clik the mouse button, but when I release the note dissapears. PROBLEM 2: Sometimes when I try to delete a midi note, the note cannot be deleted PROBLEM 3: When I duplicate a selecton of midi notes the duplicated selection has double triggered notes at random (midi merge is not on) and when I look at the midi event list while I duplicate the selection, I can see the double triggered notes in the event list. PROBLEM 4: When i'm placing the selection tool in between 2 midi notes sometimes one or the other or both of the midi notes are selected when they should not be because I inserted those notes to the grid. ( the notes should be quantized to the grid but they seem to be a little longer at the end or beginning of the note. ) THINGS I'VE TRIED: I DELETED ALL PT RELATED PREFS Digisetup Pro Tools Prefs DAE Prefs I used NORTON on all my drives. I copy the midi track to another midi track. this helps for a few minutes, but then screws up again. I track transfered the midi tracks to a new session, and that fixed it for a few minutes and then screwed up again. I Exported the midi and imported into a new session, and that screwed up too. This happens on any session now.. new or old and it sucks!! What do you think it could be?? [img]images/icons/confused.gif[/img] DIGI PLEASE RESPOND
2021 16" MBP M1 PRO - 1TB - 16GB MacOS 12.6.7 Pro Tools Studio 2023.9 (2) UA Apollo 8 Quad (1) UA Apollo 16 Quad |
Re: MIDI PROBLEMS - DIGI PLEASE HELP!!
DIGI WHAT DO YOU THINK??
PLease Help! Digi 003 Midi Problems | THE STATIC FACTORY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-25-2012 08:01 AM |
DIGI 002 MIDI Problems | timhuling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-02-2010 11:47 AM |
midi problems W/digi 001 | lechar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-21-2005 11:41 PM |
DIGI 002 Midi problems | drasmith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-17-2004 04:49 AM |
MIDI PROBLEMS!! DIGI PLEASE HELP | ManhtnProjct | Pro Tools TDM Systems (Mac) | 6 | 11-14-2001 07:04 PM |
