Old 02-19-2015, 10:02 AM
paulmitch paulmitch is offline
Default PT 11 hangs when "Restoring tracks..."
I created a session in PT10.3.8, and upgraded to PT11.3.1. I created a new session and am trying to import the session data, and it hangs on my Aux import EVERY time. It's infuriating.
Anybody got anything?
Mac Pro Mid 2012
2 x 3.06 GHz 6-core Xeon
32 GB RAM
Pro Tools HDX
3x HD Madi
Home:
27" iMac, (Retina 5k, 2017)
4.2GHz Intel Core i7, 32 GB RAM
OSX 10.3.3
UAD Apollo 8 Duo
UAD Apollo 16 silverface
UAD Satellite Octo, Thunderbolt
PT 2018.10
Work:
Mac Pro (Mid 2012)
2x3.06GHz 6-Core Xeon, 32 GB 1333 MHz DDR3
OSX 10.13.6
Avid HDX HD Madi x 3
SSL C100
Old 02-19-2015, 10:06 AM
Drew Mazurek's Avatar
Default Re: PT 11 hangs when "Restoring tracks..."
Will 11 open the original session?
www.drewmazurek.com
Old 02-19-2015, 10:08 AM
It did initially. Though all the aux channels needed to be made inactive and re-activated in order to function. Then it locked up, and hasn't opened since.
Home:
OSX 10.3.3
UAD Apollo 8 Duo
PT 2018.10
Work:
Mac Pro (Mid 2012)
OSX 10.13.6
SSL C100
Old 02-19-2015, 10:21 AM
A few things to try.
Import one track at a time to isolate issue.
Open with all plugs inactive (Shift-open), then reactivate one at a time.
Also, are there any plugins that have both an RTAS and AAX version in the plugin folders?
www.drewmazurek.com
Old 02-19-2015, 11:51 AM
Thanks Drew. I'm relatively certain that there are AAX and RTAS plugins both. The problem seems to be with Superior Drummer, but I'm not super sure yet. The Shift+Open tip was awesome. The session popped right open.
Home:
OSX 10.3.3
UAD Apollo 8 Duo
PT 2018.10
Work:
Mac Pro (Mid 2012)
OSX 10.13.6
SSL C100
Old 02-19-2015, 12:10 PM
It also seems to be Guitar Rig and Kontakt. I have updated all of those, but maybe I need to do a little more housekeeping.
Home:
OSX 10.3.3
UAD Apollo 8 Duo
PT 2018.10
Work:
Mac Pro (Mid 2012)
OSX 10.13.6
SSL C100
Old 02-19-2015, 01:03 PM
Yeah, try making sure there is NO overlap between RTAS and AAX plugs. See if that makes things settle down. It's def plugin related.
www.drewmazurek.com
Old 02-20-2015, 06:59 AM
It looks like with Yosemite, Native Instruments and the CoreAudio Manager don't like each other. Given that I'm using PT HDX, I can't currently launch Guitar Rig and some other NI plugs. Relatively large bummer.
http://www.native-instruments.com/en...tibility-news/
Home:
OSX 10.3.3
UAD Apollo 8 Duo
PT 2018.10
Work:
Mac Pro (Mid 2012)
OSX 10.13.6
SSL C100
Old 02-20-2015, 08:53 AM
It's not HDX that's the issue but Yosemite as you found out. A good thing is if you don't have NI hardware dependent plugins like GR5 or Maschine (even though you may not have the hardware controller) on a session you cans till work in PT and Yosemite. Just being in the plugins folder hasn't been a problem here (yet). The rest of NI plugins seem to be okay in Yosemite.
Jack
QAPLA!
Old 05-23-2018, 04:21 PM
firmflange's Avatar
firmflange firmflange is offline
I had the same thing happened to me today. Found out I had a “space” plug-in that must’ve been expired. After I did the shift open I deleted the plug-in and it seems to work fine now.
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Pro Tools Crashes during "Restoring Tracks" portion of startup rhythmator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-28-2014 10:42 AM
Popping sound during "Restoring Tracks" notr2d2 macOS 0 08-06-2013 10:24 AM
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" georgelegeriii Pro Tools TDM Systems (Mac) 0 11-19-2012 12:14 PM
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" bradykrzemien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-18-2009 09:18 AM
Structure "restoring tracks activating insert" for ever houser Pro Tools TDM Systems (Mac) 0 05-20-2009 02:35 AM
