Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-21-2020, 07:07 PM
Ben Jenssen's Avatar
Default Re: Opening old sessions in PT12
Originally Posted by arche3 View Post
I've aways had trouble designating the system disk that has protools 10. And when switching back to my current protools startup disk it sometimes takes a few tries. So its annoying.
I had the opposite with my mac pro 3,1; when running the PT10/OSX10.6.8 system, my sierra partition wouldn't show up in startdisk prefs. Option key on startup worked fine, though.
Old 06-22-2020, 11:09 AM
Eric Lambert's Avatar
Originally Posted by albee1952 View Post
Rumor has it that the next PT update might actually open/convert SD II(as long as you're on a Mac).
I hadn't heard that rumor before now -- that would be wonderful. Long overdue.
Old 07-05-2020, 03:20 PM
groovebrother groovebrother is offline
Hello Eric
i do not if you have solved your problem yet but here i have almost all PTHD6 versions, i think i have one PTHD7 (not sure), i have one PTHD8 and PTHD5.x on OS9.
My G4 is perfectly working so i can convert the audios for you if you want.
cheers
Dominique
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 07-05-2020, 05:24 PM
JFreak's Avatar
JFreak JFreak is offline
I'm sure nobody sends sessions over for conversion unless you are under contract with them... but nice idea offering help
Janne
Old 07-08-2020, 05:32 AM
yes right ... i must have forgotten that part.
But still, if pro tools 10 can handle it then this should be all righ for him
My soundcloud page
  #16
Old 07-09-2020, 08:00 PM
Originally Posted by groovebrother View Post
Hello Eric
cheers
Dominique
I appreciate the offer, but yeah I can't share these sessions.
  #17
Old 07-10-2020, 01:30 PM
SLK SLK is offline
I have a G5 with an HD Core in it and an extra license of 7.3.
$125 including the ilok transfer.
I'm in LA, so no shipping necessary.
I would just have to turn it on again and make sure it's still all good.
  #18
Old 09-04-2020, 03:56 PM
Hi Eric, it sounds like the new Ultimate update is able to open SDII files.
My soundcloud page
  #19
Old 09-05-2020, 06:51 PM
My tests have shown that it won't open as easily as described, but there's hope.
Old sessions must be renamed to have the .pts extension, and the audio files will be considered missing so you have to relink them. If there's an easy way to relink I don't know of it. It takes a lot of tedious clicking to find the right files for PT to search in, etc.
The Find and Relink process in general is far too archaic.
  #20
Old 09-06-2020, 10:51 AM
yep there might be an easy way to relink audio : is to rename the .sd2 extension by .wav and that should do the trick
You can use automator in case there is lot's of audio files
My soundcloud page
Error -9105 when opening sessions in PT12 Rowan Watson Pro Tools 12 3 05-11-2017 12:38 PM
Opening oversized PT12 HD session in non-HD PT12? mjpatey Pro Tools 12 6 01-10-2017 09:25 AM
Opening PT12 Sessions in PT11 Heilos4 Pro Tools 12 4 08-11-2016 12:52 PM
IO settings problems when opening PT12.5.1 session in PT8 HD nainesh Pro Tools 12 3 07-12-2016 11:09 PM
Trouble Opening PT12 williamg Pro Tools 12 7 12-19-2015 07:38 AM
