Re: Monitoring improvements needed !
S6 v2.0 is compatible with PT 11.3.2 and higher
I'm using it with 11.3.1.
As far as I know there is only one new feature that is only available with v12. I think it was having Pro Tools bank to follow the selection on the surface. Maybe someone can chime in and confirm that. It's not a feature I use.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
The new Automation Lanes on the Display Modules requires PT 12.1. There were a few bug fixes that went into PT 11.3.2 and PT 12 too.
Ok guys thx !
Can´t Walt for the update ! Sure you'll let me know asap ! See you fellows |
if you have the remote from colin broad TMC-1 (available in S6 format). I think it can do all you need and more Roland |
#16
What I'm hoping is an update to the S6 soft keys to allow access those monitor features. It would be handy to assign that to the soft key panel on the new S6 PEC module.
#17
Point of order - given that 11.3.2 is supposedly "the last PT11 update", are you giving us false hopes of a further update? ;-)
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
#18
Essentially the aforementioned x or behaviour on the source select would solve our A/B ing needs.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
input monitoring on Mbox 3 - advice needed | pennyco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-11-2010 07:49 PM |
Improvements | fsb1 | Artist Series | 0 | 09-25-2010 08:15 AM |
002r and control 24 users monitoring advise needed | crizdee | ICON & C|24 | 0 | 08-21-2006 01:37 AM |
Possible improvements to the DUC? | AVGuru1 | General Discussion | 0 | 01-21-2005 12:20 PM |
Monitoring and latency: advice needed | MadProfessor | Tips & Tricks | 4 | 12-03-2002 11:46 PM |
