Considering going from HDN to HDX - Any downsides?
I have a smooth running PT Ultimate / HDN setup on a powerful Windows workstation (HP Z820, 24 core, Win 10 Pro), but am considering moving to HDX2 to access more hardware I/O. This is mainly for mixing, only a little tracking. I use a lot of outboard hardware via inserts and am hitting the 64 I/O limit and would like to add more Symphony or Avid I/O boxes.
I know the differences between HDN and HDX, what I'm wondering is if there are any downsides or gotchas in moving to HDX. Is stability generally the same between both platforms. I've read about issues when mixing DSP and native plugins, but assuming I used all native plugins and hardware inserts should I expect any issues? On the other hand are there any upsides in my situation (besides accessing extra I/O) in moving to HDX? Will there be any differences with hardware inserts? Thanks for the help! Mike |
Re: Considering going from HDN to HDX - Any downsides?
The internal mixer is always DSP, so using a native plugin on an aux will cause an added delay compared to your native setup. Even without mixing dsp plugs with native plugs, there is always a switch from dsp to native (when used on an aux, tracks are ok).
IIRC the delay is the length of your hardware buffer (settings). |
Hi, welcome to the community.
First check your computer has enough power for the HDX cards
HD-X is just horrible to mix on if you want to combine AAX-DSP and AAX-Native plugs. Just my 2p.
Maybe the better question is: What's the upside? If you need more than 64 IO, then you have to weigh things out, but if 64 is enough IO, I'd stick with HDN. My last commercial studio had 48 IO and I never actually used it all up, even tracking 6-7 piece bands
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 08-24-2019 at 08:05 AM. |
Never had any problem with my HDX rig. Except some minor Pro Tools bugs that are affecting all users... |
I dont have any problems using all native plugins while mixing. Sometimes I dont switch all plugins from DSP to Native (but I tend to do so, dont want to do DSP / Native /DSP / Native trip for nothing) and it never caused any problems. I have a mid 2010 Mac Pro and have some fairly large mixes. When I run out of power, it's when I use a lot of very cpu intensive plugins. But I never made the test to switch one of my mix to core audio , just to see if I would gain some cpu headroom, but I doubt it would be the case. Hope this helps. |
HDN here with 56 ins and outs and very happy! lots of hardware i/o too and never had any issues with it so I can highly recommend HDN - with the new PT 2019.6 I can even record at low buffer sizes..
If you’re switching all your DSP plugs to Native, it doesn’t seem to me like you’re using any aspect of the HD-X system for mixing? Personally I find having to worry about the whole DSP-Native plug-in round trip malarkey a stress I don’t want or need.
hi,
I mix all day everyday on HDX with both DSP and native plugins and totally love it! I also appreciate the low latency tracking and easy ability to overdub into a fully developed mix.
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
What Are The Downsides Of Using Third Party Interfaces | orbro | Pro Tools 9 | 4 | 11-08-2010 03:49 PM |
downsides to "low latency monitor" mode | jacko32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-16-2003 12:27 AM |
Can this be done with success are there any downsides to this functionally | STUDIO-DE-ARIEL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2002 10:59 AM |
