Old 10-03-2017, 05:23 PM
Yourboywreck Yourboywreck is offline
Default No sound through speaker eleven rack
Hello all
I am a new owner of the eleven rack. I am trying to hook up my speakers to the rack. The speakers only can be connected using stereo quarter inch cables. I have tried every single port and combination and it is driving me absolutely insane. I am using a macbook pro and logic pro x. I have the driver installed and have used the rack using headphones. Can anyone take a look at the pic and help me figure out where to plug these into the rack and if i need another program or driver to get this to work please?
Thank you
Matt
File Type: jpg 7B227CC9-ED6C-49CF-BC78-0F056C3F93A6.jpg (60.9 KB, 0 views)
Old 10-03-2017, 05:53 PM
Default Re: No sound through speaker eleven rack
Originally Posted by Yourboywreck View Post
Hello all
Thank you
Matt
I have no idea what the photo is supposed to show.
Are you trying to get this to play stand-along as a guitar processor or interface?
What driver version have you installed in what OS version.
Is this new or a used unit? Have you ever seen it work?
Does the Eleven Rack power up?
What model monitors? Do they work with anything else?
What exact make/model cable are you using, plugged into what at each end? What 1/4" cable? Is that 1/4" TRS to XLR connected to the main output? What exact make/model cable?
Unplug it from any computer.
Get stand-alone to work with headphones.
Do a user options > memory reset from the font panel. Read the User Guide to learn how to use it with a guitar.
Is the headphone and master volume turned up? Read the user guide to understand all the volume levels in the Eleven Rack.
If you are still stuck. Then exact details. What exact model headphones, what exact model monitors, what plugged into where, what rig preset etc.
Old 10-03-2017, 06:11 PM
The pic shows the cables from the speaker. I am trying to figure out if the eleven rack allows quarter inch plugins for the speakers instead of using xlr cables. What i am using is below
Macbook pro
Os x Yosemite 10.10.5
Logic pro x
Used Avid eleven rack (restored to facotry settings)
Presonus eris E4.5 speakers
The rack sounds fine through headphones.
Old 10-03-2017, 06:18 PM
I am not following what exact cables you have plugged in at eachg end. Clear photos of the cables showing the plugs (before insertion) would help.
Do the monitors work with any other source? they have rca inputs so you should be
For whatever you are doing now (live guitar or computer playback) connect up the headphones as well.. can you hear stuff right now there?
Work out how to scroll the front panel screen rig view to the far right and see all the level meters. Do you see meters there showing main levels?
Old 10-03-2017, 06:22 PM
The speakers were working fine right before i unplugged them from my old external audio source. See the picture. Both ends are the exact same. Can these be used to plug into the eleven rack? If so, where on the eleven rack do i plug them in from the speaker?
File Type: jpg C235A537-AB1E-46E3-BBB8-E02A776619B8.jpg (31.0 KB, 0 views)
Old 10-03-2017, 06:23 PM
Uh No. The Eleven Rack main output is a pair of XLR connectors. Labeled "MAIN OUPUT", maybe those are the main outputs. :-O
You need to go read the Eleven Rack User Guide, it shows you how to hook up stuff.
You need two Female XLR to 1/4" TRS plug balanced cables (like two of these https://www.amazon.com/Hosa-STX-110F.../dp/B000068NYU)
You appear to have two 1/4" TS to 1/4" TS unbalanced cable.
Old 10-03-2017, 06:25 PM
Again....its the same on both sides
Old 10-03-2017, 06:30 PM
I plugged them in but i dont know which ports exactly they need to go into. If you could let me know that would be awesome. There are multiple ports on the back of the 11r.
File Type: jpeg BD7D9293-F6B5-460D-BCFE-9111E73343FC.jpeg (20.4 KB, 0 views)
Old 10-03-2017, 06:33 PM
Our replies/edits crossed, all you need is answered above.
Southsidemusic's Avatar
As Darryl said - You need to use the Main Output connections but you need another set of cables with XLR to 1/4 TRS
(Balanced) and your picture show TRS to TRS which won't work in XLR connections.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
no sound with mic in eleven rack? baldy5000 Eleven Rack 27 01-12-2014 02:36 PM
How to use Eleven Rack with EV Live X Powered Speaker xstortionist Eleven Rack 3 10-29-2011 06:02 PM
Eleven Rack No Sound! Ph.D Eleven Rack 40 07-26-2011 09:38 PM
Eleven Rack Modulation Effects Roto Speaker guitarless Eleven Rack 17 11-09-2010 09:00 AM
No sound from new Eleven Rack Isidor Eleven Rack 6 10-04-2010 02:28 PM
