Can\'t record to Firewire Drive - Too Much glue?
I've been trying to find an answer to my problem herein the forum and in the compatibility docs, but to no avail.
I just got a SIIG 3-port firewire card to connect my Western Digital 120GB USB/Firewire drive. It won't let me change it to a Record or even a playback drive in Digibase. Is it a partion thing I have to do? It's currently 1 big NTFS primary partion. I had it as a giant FAT32 partion before and that didn't work either. I have partionmagic so I can do any of that stuff no problem. Indexing and system restore are turned off. I have it set for Optimized for performance. Other specs: a7V600-X 3200 Athlon 1gb RAM Digi001 LE 6.4 Not sure what else
Todd Rostalski Belle Epoque Studios Mill Creek Washington |
Re: Can\'t record to Firewire Drive - Too Much glue
Does the FW drive use the Oxford911chipset? Is the drive 7200rpm or faster? IF you answer not to either of these questions, that's your problem.
Hello trostals
I don't think it's the partition, though I only say that from my experience. I've got a 120 gig WD drive in a fw/usb enclosure, also hooked up to a siig card. It has one big ntfs partition as well, and works like a charm. I did buy the enclosure seperately, ADS, with oxford 911 chipset. Was yours a package deal?
XP2500+, a7v8x-x, 60/80G drives, pc2700 Micron, SIIG 3 port, win xp home, Radeon video, ADS/WD 120 FW drive, 002r PTLE 6.1.1 stable as can be. |
Re: Can\'t record to Firewire Drive - Too Much glue?
I've had this drive plugged into a MAC before when I did some studio work at Ironwood in Seattle, and it reported it as a Oxford 911 chipset drive.
I have Western Digital's FireWire/USB 2.0 Combo SE external hard drives with an 8 MB buffer. 7200RPM. Is there a utility to verify the chipset?
Just for kicks, I would back up any files that are on the drive, and then do a full format/initialization. I had weird problems a while back, and everything was fixed simply by doing this.
Re: Can\'t record to Firewire Drive - FYI!!!
For anyone else that runs into this and uses Partitionmagic 8.0 on XP:
I looked in Administrative tools -> Computer Management -> Disk Management and my firewire drive was showing up formatted but not initialized. I had to delete the partion in Disk management, then initialize the drive. THEN I could use partionmagic to make it a great big fat32 file. As a side note, I don't understand why the firewire will record with PT and not USB2. It certainly transfers files faster. 26GB is taking about 19minutes from one drive to another with firewire - it only took 12 minutes with USB2.
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al |
Better to record to a FireWire drive? or 2nd Internal SATA HDD? | conrad787 | macOS | 13 | 06-21-2012 08:52 AM |
make firewire drive a record volume for pc and mac | isound781 | General Discussion | 6 | 11-09-2005 11:41 AM |
I can´t record/playback to/from my firewire drive | CharlyRivera | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-11-2004 05:08 PM |
stop record on firewire drive crashes PT | Charles Schaefer | Pro Tools TDM Systems (Mac) | 4 | 09-02-2004 05:06 PM |
HELP! can't record to maxtor 3000dv firewire drive? | dj:A | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-11-2003 09:50 AM |
