Old 09-24-2003, 09:24 AM
Steel City Steel City is offline
Default How to best manage tracks in LE
Any advice on how to manage the takes for each track when recording a session? I've been working on a session for a couple of weeks, and since Pro Tools doesn't destroy the .WAV file when you record over a particular track, or even a part of a track, my session is getting huge. Its probably over 3GB for maybe a 10 track session. I still have a good bit of work to do on it as well. 95% of the time when I'm working on a session, I only care to keep the most current versions of each track. Is there a clean way for me to A.) erase all previous versions and takes, and B.) Record in a way that it only keeps a history if I specificly instruct Pro Tools to do so?
I'm sure this is basic stuff, but I'm brand new to Pro Tools, and I haven't found it in the Users Guide.
All advice is appreciated.
Thanks,
Russ
Old 09-24-2003, 09:58 AM
where02190 where02190 is offline
Default Re: How to best manage tracks in LE
From the regionslist audio dropdown menu:
Select-unused regions.
Delete selected.
Old 09-24-2003, 04:00 PM
Awesome. Thanks!
Old 09-30-2003, 11:32 PM
metaltim metaltim is offline
also, i believe at the end of a take, if you don't want it, hit ctrl backspace..
it will delete the file that was created with that take, so you don't take up so much room if you do a lot of takes..
tim
Old 10-01-2003, 10:23 AM
allstaar's Avatar
allstaar allstaar is offline
I think that's actually apple+z to discard the take when you've stopped recording.
If you need to quit recording while your in record and discard the take use Ctrl + period. This also works during bounce to disk.
Old 10-01-2003, 04:19 PM
... if you use a mac
Old 10-02-2003, 05:29 AM
allstaar's Avatar
Sorry, metaltim.
I am a PC virgin.
Old 10-16-2003, 09:05 PM
marcusb marcusb is offline
Delete selected.
You might want to delete any unused playlists also before doing a select unused .. delete unused.
Personally when i'm tracking I won't clean up my session until i'm about to start mixing. Before I start a mix I like to clean up my session by consolidating all the tracks of audio i'm using. Then i'll delete all my unused playlists, then delete all my unused regions. Mind you, when I do this I have a complete backup of my tracking sessions just in case.
Cheers,
Marcus
Big ASIO setup - How do PT manage the I/O's? bredo Pro Tools 10 5 01-25-2013 12:20 AM
PT 8 Manage plugins jerberson12 Pro Tools TDM Systems (Win) 2 11-09-2011 11:16 PM
Please Weigh In: To Bass Manage or Not To Bass Manage, that is the question. Wyn Post - Surround - Video 10 08-06-2011 08:42 AM
To bass manage or not to bass manage Rick Sanchez Post - Surround - Video 35 08-28-2005 07:00 PM
How does one manage Pluggos in AudioSuite? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-09-2004 11:51 AM
