Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
Hi . Looking for help please. Just installed PT 9 HD2 today (crossgrade to Accel from PCI ). Tested it with 24/96 session. All tracks record and play fine. Then opened up multiple older sessions recorded 24/96 with PT 7 . something. All waveforms are present in the mix window , but every other channel is not playing . ( 1, 3, 5 play ; 2, 4, 6 don't etc. ) No signal present in mix window or on corresponding analog channel on my Amek desk . Stereo tracks , same problem ; left plays , right doesn't. Can anyone please tell me how to correct this situation ? Thanks so much !! Rich
Richard Dworsky |
![]() Quote:
could be quite a few things! but things to look at... Is this a fresh install of pro tools? or did you install over a previous version? What version of the operating system? under options / playback engine is the audio device set to HD TDM? in playback engine are their enough voices allocated (per DSP) to voice every track in the session!! Have you trashed prefs etc. use this app.. http://duc.avid.com/showthread.php?t=190122 Is this just one session? have you tried a new session? in this session go to the i/o setup and delete all output paths and renew them all and re-assign them all. also check the hardware setup and make sure all outputs are assigned to the desired outputs on your interface/s Chris
PT MAC Troubleshooting... http://duc.avid.com/showthread.php?t=54888 Producer, Engineer, UKmastering Mixing & Mastering Blinders_Columbia top 40 UK album charts Slow Readers Club_Build A Tower top 20 UK album charts www.ukmastering.com PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring. |
Thanks Christopher for your helpful reply . Sessions are now playing successfully after PT 9 calculates and converts PT 7 files. I think I may have selected the wrong option in a dialog box when it asks about change in setup and voices etc. Currently the settings are:
48 voices 2 DSP 96k No delay compensation HW buffer 256 samples 16 processors CPU 85% Disk buffer level 2 Cache size normal Computer is new Mac Pro 2 X 2.4 Quad core Intel Xeon with OS 10.6.4 If it helps in diagnosing what was wrong , I was also experiencing some digital clicks and pops that are now gone. Thanks again for your reply . All the best, Rich
Richard Dworsky |
![]() Quote:
Glad you're running now! A few things.. 48 voices is a low setting for a 96k session! unless you are running a very slim session!! 256 buffer might be tight if you are running any heavy RTAS plugs! again a cause of pops and clicks. 16 processors? this needs to be be lowered to avoid RTAS over messages and cpu spikes and clicks and pops. try 14 or lower? this won't effect overall performance. Chris
8.4 sessions not playing in 9 | jcolagross | Pro Tools Software (Win) | 1 | 09-26-2011 10:25 AM |
Playing old sessions on new interface | brothertony | Pro Tools M-Powered (Mac) | 1 | 02-14-2010 03:02 PM |
M-Powered 8 not playing 7.4.2 sessions. | alienaudio | Pro Tools M-Powered (Mac) | 0 | 02-11-2009 12:36 AM |
My c24 is not playing stereo my pt sessions | thegift | ICON & C|24 | 13 | 08-14-2008 12:53 AM |
Playing 7.0 sessions on 7.1 h/w buffer errors | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2006 12:57 AM |
