Old 09-04-2008, 06:24 AM
sonny7 sonny7 is offline
Default Macpro reads RAM incorrectly
I have a mac pro quad core (from 2007), 10.4.10 OS. I have 4 gigs of ram, 4 i gig sticks. I noticed that sometimes my computer will read only 3 gigs instead of 4, 2 one gig sticks, and 2 512 sticks.
The Ram is seated correctly.
To correct the problem I took the ram sticks out and "rearranged" them, top to bottom and vice versa then the computer read it as 4 one stick gigs. It only happened one time (so far in the middle of a session).
Any one else have this issue. The ram came with the computer and my nearest mac repair shop is some distance.
Could this just be a one time occurance???
Thanks
mac pro, 2.66ghz 4gigs ram, 1 internal 250 and 1 internal 500 hard drive, digi 003 board, PT 7.3
www.James Angelucci.com
Old 09-04-2008, 10:09 AM
BRH BRH is offline
Default Re: Macpro reads RAM incorrectly
I had the same thing happen with a 2008 8-core machine. Did the same thing and switched the RAM around. That helped. I think it's a mac thing.
Old 09-04-2008, 03:11 PM
docbop docbop is offline
The Mac Pro's are very picky on how your RAM is laid out across the two riser boards. The Apple technote is sparse on the topic. OWC who sells a lot of Mac RAM has a tech note of their own that has more details.
www.macsales.com
Steve B.
If you think you can or if you think you can't, you're right.
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 03:39 PM
Does PT9 reads directly from OMF-media? Arno Peeters Post - Surround - Video 4 02-02-2011 03:21 AM
Quicktime at 24 fps reads 24.x in PT HD smlworld Pro Tools TDM Systems (Mac) 1 05-26-2009 12:21 PM
partion reads transfer only? sterndrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-05-2008 02:47 PM
Athlon 3000+ reads as a 1.4 ghz neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-12-2003 11:54 AM
