Reload Dynamics II
Just loaded the Dynamics III and like them. However, I was cleaning up and accidentally uninstalled the Dynamics II. How can I get these back?
Re: Reload Dynamics II
On the Options:Plug-Ins page, pull down the menu at the top of the left column. Select "Previous Installs". You should see EQII in the list. Just select and reinstall.
Whenever you install a plug-in on VENUE using this page, a copy of the installer files is made to the User Data drive (D). This way, even when you perform an Update of the system, you'll still have all plug-in installers available, even if you've uninstalled! A full Restore, however, will wipe all installers (and all other data). -Matt
Matt Peterson Avid Audio |
DYNII can also be re-installed using any version of the D-Show Standalone Software CD, which ships with each console. All factory-installed plug-ins are contained on this CD so they can be re-installed after a System Restore operation. Simply insert the Standalone SW CD in the FOH Rack and DYNII should appear in the left hand list on the Options > Plug-Ins page.
Sheldon |
mattpete - careful with this one. If the plug-in has been disabled it remains in the previous install list. If it is removed, it no longer exists in the previous installs (the exception being system upgrades). I will search the standalone CD per Sheldon's info.
darth, you are correct, sir!
But to me, this is a bug, at least in principle. So I'll see what can be done about changing the behavior. Thanks for pointing this out. -Matt
It's not a bug per se, since it was a conscious decision that uninstall also removes the copied installer. However, I now agree that it's more benfeicial if the uninstalled plug-ins persisted under Previous Installs, and they can then permanently deleted them from this list at the user's discretion. Look for this enhancement in an upcoming release.
Sheldon |
Mac reload.. | greenetunes | General Discussion | 1 | 01-16-2014 08:30 PM |
no problem with dynamics in pt 8 problem with rane series dynamics at pt 8 | vageli | Pro Tools TDM Systems (Win) | 0 | 01-25-2011 10:00 AM |
Can Dynamics 2 and EQ 2 coexist with Dynamics 3 and EQ 3? | noharmlessrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-29-2008 11:23 AM |
Expander Gate/Dynamics III vs Drawmer Dynamics | DaveSB | Pro Tools TDM Systems (Mac) | 14 | 01-31-2007 05:26 AM |
how to reload XP? | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-24-2004 08:38 PM |
