Trouble with Sony Oxford EQ
Bought the Massive Pack 4, transfered licenses to my iLok, loaded Massive Pack into Venue, Oxford says it needs a license. Has anyone else had this problem?
Re: Trouble with Sony Oxford EQ
Sony hit me back with a solution, I'll let you know whether or not it works.
Hi Eric,
I'm pretty sure it's due to a mismatch between an older plug-in installer included w/ Massive Pack and a newer authorization given out by Sony. Massive Pack was recently updated to include newer versions of plug-ins, and your order likely hit us during the transition period. Apologies for the inconvenience. The Sony installers which match the new auth can be downloaded from the Digi support site. They're under the "MassivePack 4 Plug-in Updates for Pro Tools HD 7 on Windows XP" heading. <edit> Once you've downloaded the plug-ins they'll need to be installed manually, as described here . <edit> You should also update the console software to the latest version 1.1.1. You can download the update here. It only takes a few minutes, and all console data is preserved during the update. Sheldon |
Thanks Sheldon,
Sony sent me a new plug and resource file, which I had to load manually. Worked great. I figured that there was a PT7 change over issue because another Venue user had the Massive Pack and his plugs worked immediately, but this was pre the PT7 update. I've also heard from PT7 users that their having problems with Massive Pack, but again, this is probably the same update problem. By the way, purchased a HD2 Accel rig to run our broadcast mix, recording and campus feed. That makes 2 HD Accel rigs, and the Venue! Next stop, ICON! I'll let Darth know about the new console update. Thanks again for your assistance. It is greatly appreciated. Erik |
SONY Oxford for PT 7.2 | stargazer | Pro Tools TDM Systems (Mac) | 4 | 12-30-2006 03:26 AM |
Oxford Restoration tools, Oxford Plugins by Sony | elwoodzulu | Post - Surround - Video | 0 | 10-25-2006 08:33 PM |
PT LE and G5 / Sony oxford...more | MiamiMusicMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-24-2004 08:06 AM |
Trouble registering Sony Oxford plug in | vtone | Tips & Tricks | 3 | 12-01-2001 05:04 PM |
Sony Oxford EQ | sandman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-01-2001 04:05 AM |
