The not so obvious good things in PT8
I have to preface this by saying that around about March I will read the Ref.Guide.
One little tip that I haven't seen mentioned, is the little red button in the plug-in screens. It defaults to ON (red) and behaves like all plugins did. Turn it OFF and then select another plugin and the OFF one will remain on screen along with the new one. This is a bit like the old shift click method but this is more elegant. Great for comparing two plugins' settings. For approved controller users (003 002 etc) the control mapping is another untouted feature that I think is brilliant. To control for example the Xpand2 there are pages of controls and to page through them all can be a waste of time. Enter control maps. I have set one map as "A edit map" which just has the 6 A-edit controls, the A-level and A-pan - set as the default this covers most of the major tweaks in the A instrument. I setup similar maps for B,C and D. I hope this helps some people and I am NOT trying to teach the art of sucking eggs |
Re: The not so obvious good things in PT8
003r/i7-930/LE 8.0.1 cs2 on xp |
yes instead of it being a red square it was a red and white circle that looked like a Target.
www.klarityrecordingstudios.com |
Well there you go - I live and learn. Thanks guys.
Shows the new UI is clearer for me anyway |
what good things happened?? | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-17-2010 11:15 AM |
Latency...I tried all the obvious. Help Please!!! | 86crew | Pro Tools M-Powered (Win) | 1 | 06-10-2006 10:52 PM |
iMac G5 !!!good things and bad things!!! | Jervy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-28-2005 01:36 AM |
good things and comments | parlour snake | Digidesign Hardware & Software | 1 | 01-11-2001 10:37 PM |
PC forgot the obvious | clarpark | ProControl, Control|24, Command|8 | 2 | 06-26-2000 03:22 PM |
