Maximum width of Edit Window?
I wonder if the width of Edit Window is somehow limited to 5120 pixels? I am using three 2560*1080 displays, but cannot stretch Edit Window to fill all three of them, but only about two.
Re: Maximum width of Edit Window?
Am I the only one with this first world problem?
I would test for you but my display is limited to 3840 pixels wide. From your data I would suspect the window width is restricted to two display span, not any actual pixel amount
I think it's pure pixel maximum. I can position Edit Window to fill half of the first display, the second entirely and half of the third one. But thanks anyway!
If so, contact Avid Support and raise your concern. There should not be such a restriction and if there is, fixing it should be easy for the next release. I mean, what I am supposed to do with the thousand MIDI tracks if I cannot see them on my displays?
Oh sorry, that pun went wrong. I was thinking about mix window -- that's where width really counts
You are in trouble then. The maximum width of the Mix Window is even less; about 3840 pixels.
Not yet. That happens to be my max width currently
Raised this question for mod team. You could still do yourself (and all the others) a favor by contacting Avid Support and let them officially know you have a problem.
Ok thanks. How should I contact the support?
Mix Window Freezes but Edit Window works fine. | wwicklund | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2022 10:57 AM |
Midi edit window stuck to edit window | lvsranch | Pro Tools 11 | 7 | 04-04-2015 12:42 PM |
How to adjust Track Width in Edit Window | larsongs | Getting Started | 14 | 06-16-2014 09:14 PM |
Mix Window Channel Width? | Katrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-21-2008 07:24 PM |
changing width of markers window | fred54368 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2001 12:46 AM |
