Old 02-20-2002, 05:26 AM
DJ Branca DJ Branca is offline
Default Digi001 High latency with Sound Forge 5.0
Hi, my problem is a high latency when use Sound Forge 5.0 for recording phrase/announcer with Digi001. My computer are AMD Athlon Tunderbird 1.0GHz 133MHz, 512MB PC133, Motherboard Asus A7V133 with Via KT133A chipset(Digidesign compatibility recomend AMD+Via chipset for use with a Digi001 and Pro Tolls LE), Video card NVidia TNT2 32MB, two hard discs Quantum Fireball Plus AS 7.200 rpm Ultra DMA Atta/100 8.5 ms ts, one 20GB for OS Windows 98SE and one 40GB only for digital audio. What is problem and what is solution for use Sound Forge 5.0 with Digi001 without latency. Please help me. *sorry by my english. brancadj@terra.com.br [img]images/icons/confused.gif[/img]
Old 02-20-2002, 07:11 AM
electrobank electrobank is offline
Default Re: Digi001 High latency with Sound Forge 5.0
I use Sound Forge 5.0 on my Digi Card with no problems. Do you get any "can't acquire hardware" errors? When you are talking about latency, I assume you are referring to the time it takes for a file to play back after pressing play, or are you experiencing it if you are trying to control playback of SF from an external sync source via MTC or what have you?
What is the most common sample rate you work with? 16, or 24 bit? 44100 or 48000K? Try working at a higher sample rate. Let us know the reults. Do you have the latest Wave Drivers installed? If not you can download them from the Digidesign website. [img]images/icons/cool.gif[/img]
electrobank
2+2=5
Old 02-27-2002, 10:25 AM
André D. André D. is offline
Hi, I'm DJ Branca's partner in the studio! Thanks for your reply and sorry I'm answering so late. No, the problem we actually have is not the one you reffered to, but the fact that when I try to record something e.g. voice in the SF 5.0 there is a latency of some milliseconds that can be listened using headphones and this disturbs the person who is speaking or singing: he is listening to his own voice in real time and to the recorded voice with a few milliseconds of delay. This delay is not due to a console or something, I'm plugging the headphone direct to the Digi 001 I/O box. We tried it with several combinations of sample rate (44,1/48 kHz) and resolution (16/24 bits) and the same happens. I think there must be some more configurations to be set but I don't know where, because I already set the SF with the lowest possible buffer (Preferences > Wave). The Wave Driver we're using must be V1.7. I thank you for any else suggestions!
Old 02-28-2002, 12:46 AM
Imakerecords Imakerecords is offline
Why not record in Pro Tools LE and just import the audio file to Sound Forge?
IMR
Anyone using Sound Forge 9 with 003? emmanuelle2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-04-2007 02:05 AM
Sound Forge latency with MBox2 theagenda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-22-2007 02:03 PM
Sound Forge 7.0 golli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-13-2003 08:25 PM
sound forge 5.0 sammi10000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 08-09-2001 12:13 AM
sound forge mgiorgetti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-26-2001 01:30 PM
